Old 08-17-2016, 12:17 PM   #11
Originally Posted by lbrjet View Post
You can look at a Hensley or Propride which require no lifting after installation.
You're correct in that the WD bars are permanently installed. I love my ProPride but I find the stinger heavy. I'd guess ~50 lbs; I'll weight it next chance I get.
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 08-17-2016, 03:06 PM   #12
CaptnJohn's Avatar
Originally Posted by dpowli View Post
I currently own the original Husky Centerline hitch ( not the TS). I love the way the hitch pulls my Heritage Glen 282RK.
The issue I am having is a bad back and the heavy weight of the Husky head which approaches 75 lbs.
I am seriously considering the Blue Ox sway pro 1500 to replace the Husky. Can anyone who owns the Blue Ox please share the weight of the hitch head?
Thanks in advance.
Get a hitch pin that locks. Twice a year remove and lube the pin. At that time slide the head part way out and lube so it does not rust. Get a ball cover ~~ never remove the hitch head.
I was in the same situation. Now with the 5er hooking/unhooking is so much nicer.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
CaptnJohn is online now   Reply With Quote
Old 08-17-2016, 06:09 PM   #13
I thought the stinger stayed on and you back into it. Shows how much I know.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
lbrjet is online now   Reply With Quote
Old 08-17-2016, 09:41 PM   #14
SailorSam20500's Avatar
Copied this from the AirStream Forum. Answer is from Sean of ProPride:
Originally Posted by SteveSueMac
Sean - what does the 2.5" bar (with stinger bolted on) weigh? I never put it on a scale but I'm guessing 65 or more?
It's 55 pounds with the 2.5" receiver end.
ProPride Hitch
"The Next Generation in Trailer Sway Elimination"
Grand Blanc, MI
Tu ne cede malis
Al
S.E. Mich.
Flagstaff 26FKWS / 2016 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 08-20-2016, 12:28 PM   #15
Last FYI. I received the Blue Ox swaypro hitch yesterday. I took out our digital scale and weighed both complete hitch heads including hitch ball. The Centerline weighs 76.6 lbs. The Swaypro weights 48.3 lbs. A huge difference! Took me two hours to install the Blue Ox, had to move both batteries inboard. Can't wait to try it out!
dpowli is offline   Reply With Quote
Old 08-23-2016, 02:49 PM   #16
thebrakeman's Avatar
Ugggg...
Leaving in a standard drawbar/ball is tacky enough. Leaving an entire WDH head is just plain ugly.
...but yeah, it would solve the problem!
thebrakeman is offline   Reply With Quote
blue ox, hitch, sway, weight
