I am sure you will be fine "reinstalling" your EQ hitch. They also just came out with a new video (there are a bunch of them on their site) on setting the brackets on your trailer. If you register with them, they will send you an email once in a while with links to their videos which are quite helpful even as a review (they are not pesky with emails - maybe once every couple months). They were also helpful to me when I installed my EQ hitch 4 years ago. Just called the company with my questions and they were answered right there on the phone (no wait time, either). The dealer didn't put the brackets on right (sandwiched the breakaway wiring between the clamps and the trailer frame) and fortunately, like you, I checked it when I got home and immediately corrected it before it could do any damage. We have been totally satisfied with our hitch and would definitely buy the same brand again. It is easy to put on and off (just jack up the trailer and take the tension off first) and by putting the pins in from the inside, it is easy to put the clips through the holes. I did buy the thumb snap pins, but, am still using the old pin/clip ones since they still work fine. I lube both ends of the bars and haven't had any problems with sway or noise.
