Old 05-20-2014, 07:41 AM   #11
Kaadk's Avatar
Originally Posted by KyDan View Post
Many of us do that but you do need to make sure your brakeaway cable
is slightly shorter than your chains.
In the event of a ball/hitch failure
you NEED the brakeaway cable to pull out of the socket -before- the chains
get tight.
Never thought of that. But from the factory, mine was longer.
There's no use crying over spilt milk, unless it's on your keyboard.
Kaadk is online now   Reply With Quote
Old 05-20-2014, 08:07 AM   #12
Originally Posted by mhartzel View Post
Find a spot on the frame of your TV to attach it to.
If the receiver fails and the safety chain loops come off, it won't do you any good to have the breakaway connected there
Sent from my SM-G900T using Forest River Forums mobile app
This is the (Correct) answer! It is up to the individual if they choose to Deviate! Youroo!!
Old 05-20-2014, 08:14 AM   #13
They don't know what length set up the owner will have. The safety cable adjustment is part of (Hitch Setup). Youroo!!
Old 05-20-2014, 08:14 AM   #14
Camper Less Camping
Cajun Po-Boy's Avatar
Name:	ImageUploadedByForest River Forums1400591619.336551.jpg
When I had TT's, I used this type of breakaway line (red)...worked great!
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 05-20-2014, 05:00 PM   #15
KyDan's Avatar
Originally Posted by Cajun Po-Boy View Post
Attachment 52849
But will it pull the pin before the safety chains go tight???
No chains visible in the photo....
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 05-20-2014, 05:25 PM   #16
Attachment 52849
Those will not pull before the chains get tight and I would not use unless it was shortened.
Old 05-27-2014, 11:36 AM   #17
thebrakeman's Avatar
The cord should be attached to something that is welded to the TV. Since my SUV chain loops are welded to the hitch, and the hitch is welded to the frame (integral part of the from), I simply use the chain. But I thought all pickups had a special loop welded to the frame just for this purpose. Usually near the hitch/coupler, but not actually attached to the receiver.
OK. I've heard different theories on this. Please don't flame me, but here has been my understanding, of the order if things should go wrong:
1. Ball shank breaks, or coupler otherwise disengages from tow vehicle.
2. Tongue is "caught" by the crossed safety chains, but everything else still intact. Trailer is squirrely, but still being pulled by the chains, and braked by the controller. Pull over as best you can, and hopefully the chains don't break. If successful, you've still saved the trailer.
3. If the chains fail, then the breakaway pin gets pulled.
If the breakaway had been pulled first (full 12volts!), the result could be broken chains from the impact load (TV still on the throttle, trailer in full braking). I would first prefer to attempt a semi-controlled stop rather than sacrifice the trailer.
thebrakeman is offline   Reply With Quote
Old 05-27-2014, 11:45 AM   #18
The way brakeman described how the breakaway cable works is how I have always read.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-27-2014, 11:59 AM   #19
epicloopers's Avatar
This was my understanding of this too.
2014 Salem Hemisphere 312QBUD
2013 Ford F250 PSD
epicloopers is offline   Reply With Quote
Old 05-27-2014, 12:14 PM   #20
CLT
Next Gen Camperbot 5000XL
CLT's Avatar
The tech who installed my hitch said my breakaway cord was too short so he got me another cord off another TT in the lot. Now I'm concerned that what I have is too long. It is about a foot longer than the one I originally had.
NO TV!!! NOW WHAT???
2014 Coachmen Apex 259BHSS
CLT is offline   Reply With Quote
brakes
