Old 04-01-2019, 03:24 PM   #1
PPST Wannabe
kenandterry's Avatar
Brake Buddy Vantage Select question
PLEASE......For those with model listed above
I suspect the Brake Buddy unit may be applying the brakes in my toad too hard and too long. I have just over 50,000kms (30,000miles) showing on the odometer and Iím having brake shudder when driving and using my brakes.
If it turns out that the rotors are warped, I suspect itís from being towed as opposed to day to day usage. I say this because I live rurally, do mostly highway driving for the bulk of my mileage, and Iím EXTREMELY gentle on my brakes.
My toad weighs approximately 3800 lbs, I set the pressure at 50psi according to chart, I set it for ďproportionalĒ versus ďfullĒ braking at level 5.
Have I got the sensitivity set too high? Any input?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-01-2019, 11:27 PM   #2
Dodge Guy's Avatar
It could be from the braking. But knowing the poor quality metal they use nowadays, I’m going to say at that mileage and your light braking has caused the shutter. You have too much pad material embedded onto the rotor. This will cause the shudder.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
select
