Old 10-13-2014, 11:50 AM   #1
wifeytojosh's Avatar
Brake Control
Hi all.
I am not sure if I am posting in the correct group. Any help would be appreciated. I need to remove the break control out of one truck and eventually installed into another. The vehicle it needs to come out of is a 2000 GMC Yukon. When we had it installed, it was not pre-wired so we had it wired for break control. The vehicle it will be going into is a 2008 Toyota Sequoia. I am almost positive it is pre-wired. I can see an electrical hook-up on the rear. My question us can I just pull the unit from the Yukon without the wiring and pull it at where the caps are? Or do I need to pull the unit and wiring? Thanks in advance.
Alexis Click image for larger version
Name:	ImageUploadedByForest River Forums1413218983.294622.jpg
wifeytojosh is offline   Reply With Quote
Old 10-13-2014, 12:01 PM   #2
Cap the wires at the connections and leave em. On the Toyota if it's prewired for brakes get the pigtail to wire to your controller and it plugs in under the dash.
2016 Flagstaff 27VRL with overloaded tires from factory
2015 Chevy Silverado
Paul GA is offline   Reply With Quote
Old 10-13-2014, 12:02 PM   #3
Here's your pigtail...
http://www.hitchanything.com/2008-To...FWVp7Aod4VwAGQ
Old 10-13-2014, 12:05 PM   #4
So I need to remove that part as well to have installed into the sequoia? I am a girl so I do my best to understand this "guy stuff" Lol....I just want to make sure I will be removing at the right spots and not ruining it.
Old 10-13-2014, 12:08 PM   #5
Yes where the yellow and blue connectors are cut em loose and cap them off. Then you buy that little harness, wire it to the unit and it plugs in under the dash of the Toyota. Yes take the unit with you.
Old 10-13-2014, 12:26 PM   #6
I probably should have mentioned that I will have the RV dealer re-install the unit into my sequoia. So really I just to to cut and cap off right?
Old 10-13-2014, 12:27 PM   #7
Oh and I just cut through one of the yellow caps and noticed the wires are sautered(spelling?) together.
Old 10-13-2014, 12:29 PM   #8
You can cut it on the truck side of the connection and cap them.
Old 10-13-2014, 12:31 PM   #9
Perfect! Thank you so much for your help. I really appreciate it :-)
Old 10-13-2014, 12:33 PM   #10
Don't forget to take the mounting bracket with you!
brake control, brakes
