The prodigy is pretty simple, 3 wires. Watch the colors on the wires for the prodigy. One wire has 12 volts all the time. One wire gets tapped in to the brake light switch, the side witch turns on the brake lights. The other wire runs all the way to the back, to the trailer plug for the trailer brakes, and you may just have to run yourself. Since you said you have a trailer plug, I assume 4 wire. That would be ground, plus the wires for brake/turn and parking. Can tap these for you new trailer plug. Good luck, and hope this helps a little.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
