Old 08-09-2019, 10:22 AM   #1
Brake Controller advice
I'm in the market for a new controller. Have a Curt TriFlex and it is acting up. Disconnecting without warning and taking many tries to connect, even having to totally unplug unit to reset. Any way I'm torn between a couple units. Yes a Curt 51170 Spectrum (though my loyalty to Curt is questionable now), Tekonsha P3, and i would even consider a Redarc TowPro Elite. I like the idea of just a knob on dash and remote locating the unit. The most important is reliability, When the Curt disconnected and i was pushed thru a Stop sign I had enough (Down Hill and on a wet road the ABS kicked in). I have a 2015 GMC Canyon with tow pack and pulling a GreyWolf 17BH 4750 lbs LTG
Boborc is offline   Reply With Quote
Old 08-09-2019, 10:38 AM   #2
007matman's Avatar
Loved the P3 when I used it on my Escalade. Haven't used any of those other options.
007matman is offline   Reply With Quote
Old 08-09-2019, 10:55 AM   #3
Mopar Guy
I have had great luck with tekonsha controllers. I won't consider anything but tekonsha. I use the Prodigy P2 in every tow rig.
Dave
2019 Grey Wolf 24JS
1990 D350 dually reg cab. 5x14 injectors, s362 SXE turbo. Lenny Fustini Built 727. 4200spring stage 5 pin
Cost4133 is offline   Reply With Quote
Old 08-09-2019, 12:54 PM   #4
Agree with Dave.
When I bought my A-frame, dealer convinced me I didn't need to spend the money on a Tekonsha. Installed SOB. Finally got tired of the camper jerking me at slow-to-stops if I had the gain turned up enough to do any good at highway speeds, so I bought a Tekonsha P2. The only difference between a P2 and a P3 is the fancier display screen.
I love the smooth stops with the Tekonsha, yet I have it adjusted so it brakes pretty evenly at highway speeds - can just feel the gentlest of tugs from the camper, which tells me the camper brakes are working.
Fred W
2019 Flagstaff T21TBHW A-frame
Old 08-10-2019, 03:58 PM   #5
Grammar Pedant
67L48's Avatar
Tekonsha P3 for me. Used it for 5+ years and it worked great.
RV: 2018 Rockwood Mini Lite 2504S
67L48 is offline   Reply With Quote
Old 08-10-2019, 06:02 PM   #6
DavidBo's Avatar
The P3 is all I've ever used and I have no desire to change that. They have an excellent video to aid in initial setup, once that's done you'll be plenty happy with it.
DavidBo is offline   Reply With Quote
Old 08-10-2019, 07:32 PM   #7
For me the p3 was okay but my buttons kept getting stuck. After reading reviews, itís a common problems. I also found myself making adjustments all the time.
I switched to the Trucontrol brake control and itís pretty much fully automatic with only the low speed needing minor adjustments now and then. The only occasion when I really need to adjust my slow speed stopping is when I go from toy hauler empty to fully loaded.
deepseadan is offline   Reply With Quote
Old 08-10-2019, 07:43 PM   #8
My son has used the Prodigy for 2 years now and loves it. It worked out great as his truck and mine were both in shop for service and I had a loaner that didn't have controller in it. He needed to move his trailer so I brought the loaner over, Just put the handheld in the counsel, plugged in the 12v adapter and away we went. It worked beautifully.
TheWolfPaq82 is offline   Reply With Quote
Old 08-10-2019, 09:47 PM   #9
Sham183
mopwr4me2003's Avatar
Tekonsha p3. Works great and have had no issues at all
mopwr4me2003 is offline   Reply With Quote
Old 08-10-2019, 10:03 PM   #10
A little silcone spray fixed that problem.
As much as I loved my P3, the builtin controller in my new Ford F-150 blows it away.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-12-2019, 09:59 PM   #11
Go West's Avatar
I'm still using my 12-year old Prodigy P2. No issues ever.
________________________
2017 Cherokee Grey Wolf 25RL
2017 Nissan Titan SV 4x4
Husky Centerline TS
Go West is offline   Reply With Quote
Old 08-15-2019, 04:54 PM   #12
thebrakeman's Avatar
I'm on season #17 with the same original Tekonsha Prodigy (now called the P2). If this think ever decides to die (doubtful, as there are no moving parts), I'll get the P2 or P3.
thebrakeman is offline   Reply With Quote
brake control, controller
