Old 07-19-2015, 04:03 PM   #1
Brake Controller not releasing
About every 20-30 braking events, my brake controller will not "release" the brakes even though the TV brake is not being pressed(just released). I upgrade the brake controller to a P3 and it's still doing it. So, I went into diagnostics on the brake controller and noticed the stop lamp voltage up to 14 or so when this happens. When normal towing (no braking) it's at 0.4 volts. Is this a stop lamp switch issue or something else potentially? Is the .4 voltage normal during towing? I have verified the wiring is correct on the brake controller.
TV is a 2008 Sierra Denali 6.2
292BHDSCoachmanMN is offline   Reply With Quote
Old 07-19-2015, 08:47 PM   #2
Sound to me like an issue with the brake light switch on the TV. When this happens, do your brake lights stay on? Since you have eliminated the brake controller, I would think it is either in the trailer brakes or the brake light switch.
2015 Cherokee 274DBH
2015 Ram 3500
klrobert is offline   Reply With Quote
Old 07-27-2015, 02:19 AM   #3
Just a member
kandl's Avatar
Have you verified that the breakaway switch is functioning correctly? Not shorted?
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 07-29-2015, 08:56 AM   #4
Additional info: when this happened I observed the tail lights - they were not activated which leads me to believe it might be something on the trailer side and not the TV side.
brake control, controller, brakes
