08-11-2011, 06:51 PM
Brake Controller not working???
I decided to try and see if my brake controller works or not. Dealer installed and adjusted the controller and said it was set up to work with my truck. So today, on my street doing about 5-7 mph I slid the lever on the brake cotroller that I was told would activate my trailer braked at full power. When I did this I heard the magnet click on both axles on trailer but the brakes did nothing.  From the video that came with the brake controller it showed the slide button on the controller being slid and the trailer brakes locking up. Do I have to be going faster for this to work? On the video the trailer was traveling maybe 15-20 mph.
Now I am paronoid that trailer brakes aren't stopping the trailer, only my truck brakes are. I guess the way to check this out is to visit a large unused parking lot and with the electric hooked up, go a certain speed and stop. Then unhook the electric and repeat step 1 and see if there is a difference. Sound right to you guys??? One more thing, I wil have to try and find the box and video for the brake controller, as I don't even know the name or model of it.
Thanks Bill
Bill & Cindy McKenna
Philadelphia PA
2011 Wildwood 26TBSS
2005 Ford F150 5.4 Triton V8 4x4 XLT
08-11-2011, 07:01 PM
I can't speak for all controllers, but my factory installed ford brake controller said to brake at speeds 20-25mph starting at lv3 and work your way up untill your trailer brakes lock up. Once you reach trailer lock up, back off one half incriment at a time untill the trailer no longer locks at 20-25mph.
08-11-2011, 07:08 PM
Michigander, that is what my dvd showed also, and I did find my documentation. It is a Tekonsha Voyager 9030 made by Cequent Performance Products. Directions for this states I have to be traveling 25 mph for the test to work and to make adjustments. Thanks for your reply.
Philadelphia PA
08-24-2011, 10:56 AM
I believe the Ford system was developed by Tekonsha, so no surprise that the setup is similar.
When you apply the manual control, if things are hooked up correctly, you should feel something. Did you turn up the gain control? If you have the gain all the way up, and you still feel nothing from a full manual apply, either voltage is not making it back to the brakes, or something is wrong in the brake assemblies.
2004 Surveyor SV261T UltraLite Hybrid
08-27-2011, 06:17 PM
Well I tried the full manual apply at 25 mph and nothing. I will have to tinker with the gain control I guess.
Philadelphia PA
08-27-2011, 07:26 PM
Has your trailer ever been towed in winter conditions? Salt will wreak havoc on electric brakes. Since you're hearing the magnets engage but no braking is occurring, I'm guessing the mechanical parts of the brakes are seized up. I have that problem with a big enclosed snowmobile trailer I used to have. The salty spray from winter roads is really bad for them.
03 Chevrolet Silverado 1500, 5.3 V8, 3.73
06 Rockwood Roo 23SS
Equalizer Hitch
08-28-2011, 03:16 PM
Not been in snow or salt conditions. Bought new (2011)from a dealer in April. Will have to look at the adjustments on the controller this week.
Philadelphia PA
08-30-2011, 09:51 AM
The gain control sets the maximum voltage that can be applied.
If the max gain is set at only 2V, then a "full manual apply" will only send back 2volts. A half-apply would only send back about 1volt. If you have not yet touched the gain control, it's probably set way too low.
What controller do you have? Hopefully it has a voltage readout.
If you have a cheap time-delay controller, you should consider replacing with a Tekonsha Prodigy, P2, or P3 controller.
08-30-2011, 07:57 PM
Brakeman, I bought a Tekonsha Voyager 9030 made by Cequent Performance Products. It does not have a digital display. I will look at the gain setting and see whereit is.
Philadelphia PA
08-30-2011, 08:14 PM
Had the same problem----------------
Had the same problem, found one of the brake magnets was bad. Had the RV in the shop four times before the problem was found.
Check the brake magnets?????????????????
Sid
Sid & HRH- Daisy the Boykin.
2011 ROCKWOOD 8285 WS
2005 F-150 SUPERCREW
SUPER GLIDE HITCH
| Thread Tools |
| Display Modes |
» Recent Threads |
» Online Users: 594 |
| 122 members and 472 guests |
| 2000XLifted, 4Jeeperz, 5Galvs, acadianbob, autorot8, bean, bear17, Bearcat55, biken201, bikendan, bob7794, Borwick, brookside, Busman1947, buzzmonster, caper, Cascade Bob, cat1956, cdbus, chof16, comfun1, condo, Cowracer, cstover, cyclepuck, DAISY BOYKIN, danred, dasimser, ddavis662, deerslayer, dimurrrw, dnicekid, DonG, donn, Douglasdh62, Drmstx62, DSN46, dtolar, dunnnc, elind, forthefunofit, FreedomTracker, gbpacker, GeorgieGirl, Gman88, gmurrell, Gquist, Hammertat, Happy Vibe, icebrew, iscotty123, isz, JamesR, jasni, Jeep4Two, JJones, jkinger, jmswms, JoeR, joess, Joker, jphillips1075, jrcouture, judy3972, jwuertz, kegoneill, kjoh75, LFugate, lmcleister, louincal, maggiek, mhartzel, micalo, Mr. Legato, mrmurph, MT28rk, mtl roofer, mtnguy, NanaKaren, NancyTX, pandkm, phuss, Piston, pixleys, Playtime III, plcrph2, PrairieBoy, pwrplay, Ragin Cajun, Redheaded blue tick, rickthelen, rob and lisa, rschoono289, rstewart06, russpat, rwzahm, SabreSam, sbond, SDENN4281, shineysideup, SimchaSabre, Skippkon, skippy31405, snowbrid, softwarejoe, southernsky, Stinger, Tech Admin, texashatter, tgarner2000, thaithco, Titleguy, tmmar, TN_Jeeper, Triathletedave, Triguy, viper48, VTX Al, wakamicamper, whj77372, william.migues, wvfireboss |
| Most users ever online was 996, Yesterday at 11:04 AM. |
