Old 01-28-2016, 09:37 AM   #1
Brake controller question
I'm purchasing a two-axle pull trailer to haul my RZR to the desert and I've decided to add a brake controller to assist in stopping my rig with all the added weight. My coach, like most, didn't come with a stock brake controller so adding one is on my honey-do list. I know I'm not the first one to ever do this so I'm reaching out to all you fine people for assistance.
What all is involved with the installation of one of these? I'm fairly handy but if I'm going to be running wires the entire length of the coach then I'd rather have a pro do it.
This is the product I'm leaning toward. Robot Check
Any suggestions on this device or installation before I start in on it?
2012 Georgetown 351DS
“Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem.”
Ronald Reagan
SDlillypad is offline   Reply With Quote
Old 01-28-2016, 09:50 AM   #2
Kenny kustom's Avatar
Does it have any trailer wiring at all?
7 pin or 4 pin?
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 01-28-2016, 11:17 AM   #3
It does have the round plug (I assume 7-pin as it's not the flat one) at the receiver but that's about it.
Ronald Reagan
Old 01-28-2016, 11:27 AM   #4
fonzie's Avatar
Maybe this thread will help you.....
2008 Georgetown Brake controller connector
Fonzie
Old 01-28-2016, 11:31 AM   #5
fonzie's Avatar
The P3 Tekonsha unit is also a favorable unit recommended by a lot of members here.
Robot Check
Fonzie
Old 01-28-2016, 01:17 PM   #6
If it has the 7 pin, then the wiring should be there. There should be a plug, under the dash to plug the controller into. Easy.
I like the P3.
2016 Sabre 36QBOK
Old 02-01-2016, 03:17 PM   #7
OK, so I spent a good portion of my Saturday upside down looking under my dash for a pigtail to hook up to my new brake controller. I couldn't find anything.
I'm at a loss... I guess I should either plan to take it in or call an RV service center and hope they guide me through it over the phone.
Ronald Reagan
Old 02-01-2016, 05:24 PM   #8
fonzie's Avatar
Did you take the instrument panel out as mentioned in post #4 thread?
Fonzie
Old 02-02-2016, 06:56 AM   #9
53flattie's Avatar
I have no idea where they put these on RV's, but on trucks they can be away from where you might think... On my Tacoma, it (the pigtail) was behind the kick panel by the driver's left foot. Point being - just because it's not behind a panel in the dash doesn't mean it's not there somewhere.
2015 Rockwood 2306
2015 Tundra CrewMax
53flattie is offline   Reply With Quote
Old 02-08-2016, 01:26 AM   #10
if its a GM chassis, you may have to get a harness, and it will be plug and play into the power distribution box.
'07 Toyota Tundra 5.7L DC 4x2
'16 Surveyor 226RBDS
Nights camped 2016 - 3
Nights camped in 2015 - 20
Ditchooker is offline   Reply With Quote
brake control, controller, brakes
