01-22-2013, 03:36 PM
Wanna Be Camper
You sure that is the plug? On my 04 1500 and the 08 2500 the wiring harness was tied with a zip tie to the emergency brake cable right up against the firewall to the far left of the footwell. And it was a wiring pigtail with the plug on the end, the tie had to be cut to get the pigtail out where the adapter could be plugged into it. Both of my trucks had factory tow packages with the plug on the bumper and receiver, does yours? The plug in your pic almost looks like the OBDII plug.
FWIW, that P3 and harness is the exact stuff I used in my 04 and 08.
John & Deb
2011 Flagstaff V-Lite 30WRLS
01-22-2013, 03:38 PM
This was under the steering column sighlty to the left. As far as the towing package I'm not sure if it came with it or not, it was my father's and sadly he passed away so I couldn't ask.
2014 Silverado Crew Cab 1500 5.3ltr
01-22-2013, 03:41 PM
Wanna Be Camper
Sorry for your loss. Does the truck have the 7 pin connector beside the license plate and the receiver under the bumber for the hitch to go into?
John & Deb
01-22-2013, 03:43 PM
Thanks, no I've had to order the 7 pin connector and a receiver. Ball was on the bumper.
01-22-2013, 03:46 PM
That is your OBD2 diagnostic port to check if a check engine light comes not for a trailer brake controller. There should another under the dash somewhere else. Check your owners manual to make sure your truck is prewired for one. If it is it will give a location to find the plug.
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2014 Honda Pioneer 700-4
2004 Yamaha Grizzly 660
01-22-2013, 03:49 PM
daydreaming about camping
what he said. that is the OBD port.
On my 05 Ram the plug (which BTW is 4 pin) was way up the left side above the parking brake all the way to the firewall. I had to put my head under the brake pedal to see it. I also had to run the adjustable pedals all the way out to get my hand back there as the rack and motor for that system was in the way.
Note: unless you truck came with trailer tow group, the plug may not be there. You should check with the dealer on it, they can run your VIN to tell you what groups were installed. They can also sell you the pigtail, though Prodigy also sells a truck specific plug for all their products.
2013 Coachmen Freedom Express 320BHDS pulled by a 2005 F250 King Ranch CC
A rainy day camping is better than a sunny day at work.
01-22-2013, 03:52 PM
Alright thanks! the guy at O'Reilly's didn't know what he was talking about then. I have never installed one so I took him at his word he said it was the brake control plug but I started doubting it when I started looking around online.
01-22-2013, 04:11 PM
I had a 99 Durango-----------
The 4 pin plug is all the way to the left, tye wrapped or taped to the emergency brake housing. As stated before, you have to stand on your head just about with a flashlight to see the plug.
I have the pigtail, you are welcome to it free if you pay the mailing.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
01-22-2013, 04:48 PM
Is this it? This was the only other unused plug I could find. It's right up next to the E brake housing.
01-22-2013, 04:50 PM
this is what it should like like:
01-22-2013, 04:57 PM
Ok, then yea I don't have that plug. Only one I have is the green one you can see in the background of that picture.
01-22-2013, 04:59 PM
make sure you have your hand way up on that wire harness, the plug may be taped up all the way where the wire loom enters through the firewall. I recall it was a royal PITA to find.
01-22-2013, 05:53 PM
I looked all up in there and it's no where to be found.
01-22-2013, 07:00 PM
Commercial Member
If you don't have the factory tow package, the plug isn't there.
They run the factory 7 way plug and wiring harness with the receiver hitch when you get the factory package.
You will need the full brake controller install, with hot wire, brake wire, etc to a Bargman 7 way plug on the rear bumper.
Steve and Vicki
2 kids
2011 Dodge 3500 CTD Outdoorsman
(Tweaked!!)
2013 Columbus 320RS-ITS HERE!!
01-23-2013, 08:25 PM
you could take the VIN to the local Dodge dealer and they'll tell you if it has the factory tow package.
externally, if it doesn't have a 7-pin connector on the rear bumper and no Type III/IV receiver, then it's a good bet it doesn't have the factory tow package.
no need even looking under the dash.
