Old 08-28-2012, 10:35 AM   #1
Brake controller - warning and question
First the warning...Don't spill your morning cup of coffee over your brake controller. I did this earlier today and found out it is bad for them.
Parked and noticed the brake lights on, then noticed the brake controller light on. All while I had the keys in my pocket. Anyway ended up unhooking it and coming to the conclusion coffee had got down into it and well electronics and liquids don't play well together.
So, needing a new controller. See by some posts on here that the prodigy controllers are well thought of. Also mine, which was installed by the RV dealer, appeared to be a time delay controller, thinking a proportional controller would be better, thoughts??
thanks
David & Sherry
2012 Wildwood 28BHXL
2013 GMC Sierra SLE
wvcampincpl is offline   Reply With Quote
Old 08-28-2012, 10:42 AM   #2
Dave_Monica's Avatar
A proportional BC is the way to go...I had a P3 that worked much better than the solid state one it replaced.
Dave
Old 08-28-2012, 10:53 AM   #3
Triguy's Avatar
I'm a fan of the P3 as well. Much better than a time-delay. P2 or P3 is the way to go IMHO.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 08-28-2012, 12:11 PM   #4
caper's Avatar
A RV repair tech. told me the time delay should only be used if towing animals. Upgraded to a P3 will not go back to a time delay controller.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
caper is online now   Reply With Quote
Old 08-29-2012, 10:05 AM   #5
Helmsey's Avatar
I went from a time delayed controller (1 trip) to a P3 and won't be without one now.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
Helmsey is offline   Reply With Quote
Old 08-29-2012, 10:14 AM   #6
great white's Avatar
Another vote for the P3:
Although mine looks a bit altered, it's all Tekonsha.
I did relocate the manual lever though:
It made this trip:
Without a problem. As you can see, it deals with up hill, downhill, high speed, low speed etc with ease.
It's a little more expensive than an older tech unit, but I highly recommend it.
2011 Flagstaff Classic Superlight 831RLBSS "Atrium slide"
Husky Centerline Hitch
2016 Ford F-150 EcoBoost SuperCrew, Lariat Sport, Max Tow package
great white is offline   Reply With Quote
Old 08-30-2012, 01:46 AM   #7
Just a member
kandl's Avatar
Originally Posted by great white View Post
It made this trip:
Starting gate was Comox Valley? To Gander? No matter, that's one monster of a haul!
For the OP - P2 stuffed into that otherwise useless little cubby designed into the early 4th gen Rams. No issues with this BC over the last year and 12K km.
Keith, Lori & the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2009 Dodge Ram 1500 CC 4x4 (ya.. it's got a Hemi
kandl is offline   Reply With Quote
Old 08-30-2012, 02:01 AM   #8
Rsgtivr6's Avatar
P3 is a great controller. Dad had a P2 before his integrated in the Denali HD, but that was also a good controller. I like the diagnostics and info the display has on the P3 better, though.
TV: '17 Ram 2500 Big Horn CCSB CTD 4x4
TT: '18 Wolf Pack Limited 325Pack13
Tow Acc: Andersen Ultimate Hitch 2 goose ball mount, AirLift 5000 bags and HD compressor system
Rsgtivr6 is offline   Reply With Quote
Old 08-30-2012, 04:05 AM   #9
Yup. I'm SAR. Comox to gander, 442sqn to 103sqn.
The P3 was hook it up, adjust it up and go. Worked great!
Old 08-30-2012, 06:02 AM   #10
Wanna Be Camper
SaskCampers's Avatar
Have been running the same P3 in 2 different Ram trucks and never and issue in 6 years and 12k miles. Only thing is if it is in the truck unused for any time, every once in awhile it will be locked up when you hook up and it needs to be unplugged for a few seconds then rehooked and all is well. I also use it with my 18ft flat deck hauling water once a month and every spring abt 12 trips in a row to refill the pool as well and it adapts very easy to the different weight and trailer balance for braking.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Days Camped 2016: 3 2017: 0
brake control, brakes
