01-14-2013, 05:19 PM
Brake Controllers
We are buying a Windjammer trailer and will tow it with a Silverado pickup. The dealer will install a Hayes Energize III brake controller as part of the deal. Any opinions on this unit?
We are relatively new to the RV scene and don't know much about the equipment other than the brake controller applies the trailer brakes when initiated by the tow vehicle. Thanks.
01-14-2013, 06:04 PM
My brake controller failed last year while on a trip to MD and the only thing I could find was a Hayes unit. So far it has performed without any problems at all, although if I had a choice I would probably select one of the Prodigy models as they seem to be the most popular from what I read on the forums.
01-14-2013, 08:57 PM
go with a Prodigy. best controller for the money.
01-17-2013, 04:44 PM
Prodigy P3 is excellent!! Worth the few extra dollars.
01-17-2013, 05:12 PM
I inquired about a P3 at a dealer not too long ago, they had none in stock, but have the P2. For a 2 axle travel trailer, Does the P2 behave exactly the same as a P3? Oviously don't need some of the extra fetures of the P3 for a single travel trailer, but wondering if the controller electronics and algorithms are the same otherwise.
They also fed me some story that the P3 has been obsoleted, and only make the P2. I don't beleive it...unless there is a new prodigy comming?
01-25-2013, 10:44 AM
P3 is obsolete? Yeah, you certainly were fed a story! I would take my business elsewhere. You can go on Ebay and find a P3 brand new in the box. The displays are different than the P2 and it is colorized to your liking. I brought mine to the TT dealer and he put it on in 10 minutes for free.
01-25-2013, 11:19 AM
Another vote for the P3, I won't have anything else after using it.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
01-25-2013, 12:26 PM
I've attached a link to Hayes web site. The Energize III is a proportional controller...don't know how it rates compared to the Prodigy P2 or P3.
Brake Controllers | Hayes Brake Controllers
Dave
01-25-2013, 01:37 PM
I went with a prodigy and it's been great.
Getting a new silverado next week that has the factory brake setup on it. No idea about it but heard the ford ones are good. I guess I'll find out.
The expedition was factory wired for a brake controller and installation took 10 minutes - 4 to find the plug under the dash and 5 to install 2 screws and 1 to attach things. If your truck is prewired i'm sure you can do it yourself. There is 'adjustment' per se- you hook up and hit the brakes and adjust the knob on the unit per the instructions.
I leave mine alone and when in our hilly graveled campground manually add more trailer brakes
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
01-25-2013, 02:08 PM
I have a Prodigy P2, ordered from Etrailers.com. I watched their video on installation and had mine installed with an hour, that includes getting tools, drilling two holes and cleanup. No problem to adjust. I tested mine out good when my left rear tire blew on my PU. Everything worked as it was supposed too.
2009 Palomino Puma 25RS
2007 Chevrolet Silverado
Prodigy P2 Brake Controller
01-25-2013, 10:32 PM
Thanks for all the responses. I decided on the Prodigy P3. Watched a youtube video; mount the bracket and hook up to four wires already under the dash. The dealer said he would install it for no additional charge.
01-25-2013, 11:59 PM
Too old to be too smart
You'll be happy with your P3.
I love mine, and when I'm not towing, I use it to monitor my electrical system's voltage.
Pop
Terry 250RKS, perfect for the two of us and the pups.
2000 F-350 7.3L CC/LB 4WD Lariat 3.73's
01-26-2013, 01:52 AM
I have the Tekonsha Primus and I like it, easy to operate and install.
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
01-26-2013, 07:14 AM
Wanna Be Camper
Had a P3 for years and loved it. Only issue I ever had was it would lockup once in awhile when it wasn't used for a longtime (a month or so). So I would just unplug it, wait 10 sec and plug it back in and all was fine.
John & Deb
2011 Flagstaff V-Lite 30WRLS
01-26-2013, 10:53 AM
I have a P3 and love it, I mounted mine in the middle
2009 Sabre Palomino "Sissy" 1998 Chevrolet K3500 6.5 Diesel "Brutus"
01-26-2013, 11:08 AM
I have the P1 and like it better than the Reese activator3 which I also have for my truck
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
03-31-2013, 12:49 AM
I currently have a Redline brake controller that is a solid state time-delay type. It's pretty basic with the thumbwheel and emergency brake slide switch. It works...but needs frequent adjustment as driving conditions change. I would like to see about moving up to a higher-end controller that has a display and uses an accelerometer. I have been told by some to go with a Prodigy and others have said Hayes. Any input? Should I just splurge on a Prodigy P3 and be done with it?
TT: 2010 Flagstaff 27BHSS; TV: 2002 F-250 Lariat Crewcab 4X4, 7.3L Powerstroke, 3.73 LS
2015: 11 total days camped
Huntsville Space Center, AL; William Bankhead National Forest, AL; and Gulf State Park, AL
03-31-2013, 07:02 AM
Go with the P3 .... Best brake controller I've used in 20 years of towing!
2013 Lacrosse 318bhs
2010 Toyota Tundra Crew max 5.7 flex fuel / Installed airlift ultimate 5000 air bags and smart lift automatic leveling system.
Yamaha EF2000iS 2000 Watt Inverter Generators
Minooka, IL.
03-31-2013, 08:03 AM
Love my P3
Joe & Anna & the boys
2012 Toyota Tundre 5.7
2013 Prime Time Lacrosse 318 BHS
2013 Night Camping 41
03-31-2013, 08:36 AM
I agree with Raceday the only way to go, But raceway what are all those switches for? Do you have after burners installed or something? on the left of your dash. Just curious.
Coachmen M/H
Concord
2018 / 300 DSC
