Old 03-10-2016, 08:37 PM   #1
phillips's Avatar
brake gain setting
i have my gain setting at 8 after tuning it and it seems to be the right amount of brake...cant feel the trailer pushing truck and also cant feel truck being pulled by TT. basically cant tell the TT is there when braking which i assume is the way it should be. my concern is that with the gain set to 8 and the TT being dry, once the TT is loaded am i going to have to adjust the gain even higher? 8 just seems to be high when reading what others have there gain set to.
TV-2013 F-150
TT-2016 Apex 300BHS
phillips is offline   Reply With Quote
Old 03-10-2016, 09:23 PM   #2
CaptnJohn's Avatar
If at 8 on low you still can go to 9 or 10 when loaded. Also, you may find a low number in the medium setting most comfortable. The gain on my F250 is at medium 7 with a 11,000 5er. Individual setups from trailer to hitch and truck will dictate what feels best.
2017 Montana HC 370BR
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 03-10-2016, 09:28 PM   #3
Canadiancrew's Avatar
I have mine set to 8 as well for a 32 foot trailer behind my f150. You can always just turn it up a bit when loaded.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 03-10-2016, 09:44 PM   #4
Wire Wrat's Avatar
Brake gain
TV-2013 F-150
TT-2016 Apex 300BHS
I have mine set at 7.5 in the medium setting. I have a 7800 lbs trailer un loaded I had it weighed at the way station (ready to camp loaded with all our necessary equipment) it was 8180 lbs. I have pulled this 5000 miles and had no trouble stopping this rig.
Be ware of the things you say and do for little eyes are watching you. Believe it or not, YOU are a role model
Wire Wrat is offline   Reply With Quote
brakes
