12-03-2017, 02:36 PM
Braking System
Hello, I recently purchased a 2017 Salem by Forest River Cruise Lite 195RB. I’m having a hard time finding information on the type of braking system. I’m towing with a 2015 Dodge Durango RT. I have the tow package and electric brake system. Someone told me the the braking system on the trailer needs to either be pulsing or electric as well, otherwise by brakes on the dodge will wear out fast. Can someone shed some light on this. Thank you for the help.
12-03-2017, 02:57 PM
You will have electric brakes on your unit. You can see it for yourself if you look behind trailer tire. You will see a wire going into hub assembly most likely a blue wire.
2016 Ford F250 XLT 4X4 6.2L
Hensley Arrow
12-03-2017, 03:53 PM
Thank you so much. Do you know if I need to manually adjust anything on the trailer?
12-03-2017, 04:44 PM
NH Maple Maker
You won't need to adjust anything on the trailer. You will have to adjust the "gain" on your electric trailer brake controller. You adjust that while you are towing. When it is properly adjusted the trailer shouldn't be pushing or pulling your tow vehicle when braking.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
12-03-2017, 05:25 PM
The instructions for adjusting the brake controller should be followed. If adjusting the controller does not give the desired results, the brake shoes on the trailer axle should be checked and adjusted.
03-09-2018, 10:00 AM
I was under the impression that the electric trailer brakes were non-self adjusting from the factory? Which means they occasionally need to be adjusted. My TT manual is in the trailer in storage, but don't new trailers need brakes adjusted at 500 miles?
Sorry, we just bought our first TT in Oct, and I've read so much online and in this forum that it sometimes blends together.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
03-09-2018, 10:26 AM
The brakes will need to be checked/adjusted periodically as they will wear. Most TT have drum brakes which adjust the same way non self-adjusting brakes worked on older vehicles with a star wheel behind a small rubber plug on the bottom inside of the wheel assembly.
Here is a quick example.
https://www.etrailer.com/question-40801.html
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
03-09-2018, 11:04 AM
Some TT electric brakes are self adjusting. My TT has them, still undecided on how well they work. When I picked up my TT last year they were too far out to grab and self adjust.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
03-09-2018, 12:15 PM
Just as confused as you
That brings to question how self adjusting brakes work on a trailer? Older cars and trucks needed to be backed up then firmly apply the brakes. Is this the same for trailers?
Richard & Jill
03-09-2018, 12:18 PM
Per Lippert;
Brake auto-set corrects clearance during every stop.
03-09-2018, 06:17 PM
So the brake magnet rotates on the bracket to set adjustment?
Richard & Jill
03-09-2018, 07:36 PM
03-10-2018, 06:47 AM
NH Maple Maker
With my reply to the OP I was assuming that the brakes on his new TT were properly adjusted and that he was asking how to keep from wearing out the brakes on his TV. If he has Lippert axles like my my TT does his TT brakes are self adjusting. The way to control how much the TT brakes is by adjusting the gain on the controller in the TV.
Russ
03-12-2018, 04:07 PM
Your Durango does not have an "electric brake system". You may or may not have wiring for electric brakes, but you will need to add an electric brake controller.
03-15-2018, 08:14 PM
I never thought about that, but I suspect you are right. I should have remembered when my DW had a Durango with the tow package, the wires and 7-pin socket were there, but it needed a brake controller installed. She even had the 7-pin to 4-pin adapter in the glove box when she bought it new.
Richard & Jill
03-22-2018, 10:15 AM
Right. Some new tow vehicles can be optioned with an integrated brake controller, but so far, those are limited to pickup trucks, and some larger SUVs (Expedition, etc).
03-23-2018, 05:30 AM
NH Maple Maker
That was one of the options that I made sure that I got when I got my new truck.
Russ
