Old 05-27-2014, 11:25 AM   #1
tuna's Avatar
brand new tow setup suggestions
My wife and I are newlyweds and are looking at getting a new TT and TV. Here is the TTwe're looking into:
2015 Salem 30KQBDSS
Hitch Weight: 899 lbs.
Dry Weight: 6,884 lbs.
Cargo Weight: 2,777 lbs.
I've considered a 3/4 ton but I'm leaning towards a 1/2 ton ram with 3.92 gears. Is it worth spending the cash and going with the 3/4 ton in everyone's past experience? I'm hoping a good WDH and a 1/2 ton properly equipped will get the job done.
I've got little experience with pulling so hoping to gleam a little knowledge off you fellas!
tuna is offline   Reply With Quote
Old 05-27-2014, 11:32 AM   #2
The one thing you need to watch with the ram is payload. It is only around 1400 lbs but if you start putting extras on it you will have much less. My 2013 RAM 1500 quad cab big horn with ram boxes only has 1100 lbs (less than the minivan that I traded in for it).
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 05-27-2014, 11:40 AM   #3
x2. You'll likely max out your truck payload before you even start packing. I would think you'd be close to max tow weight as well. If you plan long-distance trips or venture into the mountains, a 3/4 ton will be needed.
Don & Beverly, Chattanooga, TN
2011 Ram 1500 Quad Cab
2014 Rockwood Mini Lite 2304
2013 Rockwood Signature Ultra Lite 8310SS
Don0426 is offline   Reply With Quote
Old 05-27-2014, 11:56 AM   #4
Get the 3/4 ton. I thought I could get by with a 1/2 ton and regretted it for 3 yrs. Picked up a one ton and night and day difference. Don't hear many complain they have too much truck.
2012 F350 Lariat CC SRW 6.7L Powerstroke
pwrstroke2012 is offline   Reply With Quote
Old 05-27-2014, 11:56 AM   #5
tuna's Avatar
So 3/4 ton it is! Will having the 3/4 ton take away some of the sway issues or would it still be a good idea to invest in a good hitch? Budget isn't an issue but we're going to have a baby sometime within the next year so safety is priority.
Sent from my SM-N900V using Forest River Forums mobile app
Old 05-27-2014, 11:59 AM   #6
Hard to say as the towing capacity\payload range can be quite large for a particular truck depending on its configuration, 4X4 vs 4X2, regular cab vs quad cab...etc etc. Some "1\2 tons" come close to "3\4 ton" specs.
Check manufacturers websites to see what each model\configuration is rated for and then compare that to the TT specs keeping in mind that the hitch weight you listed is going to be significantly lower than the actual weight once the trailer is loaded.
And, it's not a bad idea to have more capacity then you need in case you decide to get a bigger trailer in a year or two.
_______________________________________________
Tim & Jenn
2009 Forest River Grey Wolf 235 5er
2003 F-350 Superduty 6.0 l Diesel
DSP 17K
aiscpl6 is offline   Reply With Quote
Old 05-27-2014, 11:59 AM   #7
Camper Less Camping
Cajun Po-Boy's Avatar
If you plan on towing frequently and over long distances here and there, you'll appreciate having a 3/4 ton truck.
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 05-27-2014, 12:04 PM   #8
epicloopers's Avatar
For that much tongue weight you will most likely still need a good WD hitch even with a 3/4 ton. For my 2014 F250 the factory max tongue weight without WD is 850 lbs. You will definitely be happier with the 3/4 ton if you drive in any kind of hilly terrain though.
2014 Salem Hemisphere 312QBUD
2013 Ford F250 PSD
epicloopers is offline   Reply With Quote
Old 05-27-2014, 12:30 PM   #9
DaveSchwartz's Avatar
Another vote for a 3/4
I've always (except for the pull home from the dealer) used a 2005 GMC 2500HD D/A to pull my ~5000lb max TT (never the slowest thing on the road). I've never even had the sway control connected when travelling and never had sway in a multitude of situations. The 3/4 rear is not prone to sway and E-rated LT tires are part of that.
That truck is about to start a new life pulling a 10,000lb 5er and I don't regret those previous years when I was 'over-trucked'.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 05-27-2014, 12:33 PM   #10
MtnGuy's Avatar
Yes.
I went with a 1/2 ton truck, and I am nearing my GVWR with a tongue weight that is lighter than the 1 you listed.
