Old 07-20-2012, 07:56 AM   #11
Missing Link
cyclepuck's Avatar
It may not void the warranty but if the diff. or trans had issues it will give them a reason not to cover it.
2014 Puma 30-DBSS
2014 Ram 2500 Mega Cab 6.4L
cyclepuck is offline   Reply With Quote
Old 07-20-2012, 08:14 AM   #12
TURBS's Avatar
If you want it to run like a horse you have to race it like a horse!
That's my motto!
Old 07-20-2012, 08:43 AM   #13
I did not want to run into potential problems later, that is why I personally drove all over the place to get to 1000 before towing and followed the recommendation......Legally, I do not see how they can refuse to cover something listed in the warrany unless it is expressly stated in the owner's manual. They will lose in court.
2011 Lacrosse 318BHS Touring Edition
2012 Ford F150 SupCrew 4x4 XLT 6.5' Max Tow
padave65 is offline   Reply With Quote
Old 07-20-2012, 08:50 AM   #14
wv campers's Avatar
We are camping this weekend so that is why I didn't want to pick it up now. Would rather be safe than sorry. Should be able to get a nice break in period before our next trip.
wv campers is offline   Reply With Quote
Old 07-20-2012, 10:26 AM   #15
wv campers's Avatar
I've seen all the post about the power of the ecoboost but has anybody noticed a difference in towing with the built in sway control?
Old 07-20-2012, 11:41 AM   #16
Flagstaff 625D Popup
Easy, customer abuse/misuse. Happens all the time.
Bean
bean is offline   Reply With Quote
Old 07-20-2012, 11:45 AM   #17
I pull a 3,000lb pop-up (Flagstaff 625D) and I don't even know it is back there, so I can't comment.
Bean
Old 07-20-2012, 12:38 PM   #18
Missing Link
cyclepuck's Avatar
I've got the chevy 1/2 ton with built in sway control. Pulling 8k & no sway at all even with passing rigs but did add a single friction sway control for cheap added security.
2014 Puma 30-DBSS
Old 07-20-2012, 02:50 PM   #19
acadianbob's Avatar
Originally Posted by TheSasks View Post
You are not breaking in the engine etc like in the old days. You are running in the gears in the diffs. If the book say 1000 mi they mean it. Do what the book says not the dealer unless you don't mind the possibility of having whining gears and maybe worse. And Ford will know what you did no question about that.
X2! And you will be blown away with the difference from your 4-speed 5.4
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 07-20-2012, 02:53 PM   #20
acadianbob's Avatar
Then I would say that your sway control has never kicked in. You would know it if it actually came into play.
If you trailer and hitch are set up right, you should never need this feature. Nice that it is there though just in case.
