03-07-2015, 03:45 PM
Excellent! I've changed the standard lanyards on all of the trailers I have with these!
03-07-2015, 03:49 PM
Yep, I use them and like it. You can find them at Tractor Supply, auto parts houses, and trailer parts dealers.
2011 Flagstaff 831 RLBSS
03-14-2015, 07:34 AM
Did not know about these either great idea looks like i will be getting 1 ASAP !!!
03-14-2015, 07:43 AM
Interesting. What a great idea. My 2015 still uses a standard cable.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Be careful! Remember the cable must be short enough to pull the pin if the hitch
comes off the ball. This means it needs to be just slightly shorter than your chains.
I've always threaded my cable thru my WD hitch and that keeps it out of trouble.
It won't get pulled in a turn or drag the ground. If it was dragging the ground it would
be way longer than my chains which as mentioned is not good.
Peace!
Dan & Rita D
03-14-2015, 07:47 AM
Agree with the above except cable needs to be a Little Longer than the chains! Youroo!!
03-14-2015, 07:53 AM
IF the cable is longer than the chains--
and the hitch comes off the ball
and the chains get tight
and the cable is not pulled because it is longer than chains
you wind up going down the road with your trailer dragging and the
emergency brakes will not be activated.
I want my pin to pull out so that monster back there is trying to stop
itself while I am trying not to mess my pants and stop the truck and
keep everything on the road!!
Peace!
Dan & Rita D
03-14-2015, 07:57 AM
Originally Posted by mike.t
I saw them before. How well do they work? I was a little concerned I would forget to hook it up because its coiled up under trailer frame. for the time while I make up my mind I put a small loop in the existing cable and use a very light weight zip tie (one that will break easy) to keep the loop. This takes up enough slack to keep it off the ground.
Think about things before you do them make life easier not harder.
03-14-2015, 08:08 AM
If cable is shorter than the chains it can (Sometimes) be pulled/activated during sharp turns! Youroo!! USA Flag!
03-14-2015, 08:19 AM
If the coupler comes off the ball and safety chains are still attached, the 7 way will still be connected in most cases. Breakaways are if the trailer should become completely detached from TV?? I really could be wrong. I just don't think I want trailer brakes locked down when safety chains are still attached. Again I could be wrong!!
03-14-2015, 10:15 AM
uh. I also thought the same thing. If a person does not want to buy it that is up to them.
03-14-2015, 10:19 AM
Shorter than the chains is the proper way so the chains trap & hold the tongue from hitting the ground, while the brakes are applied.
03-14-2015, 11:46 AM
This has gotten into some interesting topics. Let me ask the question "What is the most common thing that happens when a trailer comes loose from the tow vehicle"? Has it ever happened to anyone here? Have you ever seen a TT on the side of the road after it came loose? Is it usually human error during hook up?
03-14-2015, 03:41 PM
Breakaway cable
I have had it happen. Not with my TH but with a boat. My son hooked it up and it did not seat all the way on the ball. I do not have trailer brakes on my boat as it is a single axle trailer and only weighs about 4000 lbs. When it bounced off the chains extended tight, and then tugged the boat forward, then yo yoing until I can get stopped. The only damage was the tongue jack hand crank collided with my tailgate, so now my son has a nice reminder winking at him every time he hooks up. And then I go behind him and verify. It was scary and could not imagine a heavier trailer.
03-14-2015, 03:49 PM
(Dry Huunday)
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
03-14-2015, 03:51 PM
The old guy knows a thinger2. Ya really want to trap a failed hitch situation with chains and plug still intact.. and stainless steel cables are really the way to go over those springy plastic jobs.
It's a fail-safe that should be 'absolute'.
03-14-2015, 04:24 PM
itch'n to road trip
We have one... the original one would drag and this one work well....so far.
2012 Ford F-250 King Ranch Super Crew Cab 4x4
2014 Work & Play 25ULA
Paula Drake, Ken Cooksey, Sunny Delight, Valor & Scarlet Begonia
Jasper Ga.
03-14-2015, 04:54 PM
Well, those with the coiled cables just wasted money because they are totally useless if the trailer comes loose and hangs on the chains. They will never pull the emergency pin so what good are they?
03-14-2015, 05:16 PM
I have always taken my cable and twisted it a few times so it sorta has a loop in it.
2012 F350 Lariat CC SRW 6.7L Powerstroke
