Old 04-03-2013, 06:12 PM   #1
TURBS's Avatar
bumper mounted bike rack. "why you should not"
Found this today !
bikes are soon to disengage from trailer.
Old 04-03-2013, 07:02 PM   #2
dot76's Avatar
I have seen many of those racks used flawlessly. But one must strap down the bike prior to pulling away.
dot76 is offline   Reply With Quote
Old 04-03-2013, 07:14 PM   #3
When you couple the bounciest end of the camper with these ridiculously cheap bike racks, I don't know how any of them stay on.
I sure wouldn't have been taking that picture from right behind that guy!
bakken is offline   Reply With Quote
Old 04-04-2013, 11:02 AM   #4
X2 That looks like a hitch mounted rack, so I wouldn't be blaming the bumper for the owners failing to properly secure the baikes.
Len & Cheri is offline   Reply With Quote
Old 04-04-2013, 06:20 PM   #5
Dodge Guy's Avatar
Secured properly it is a non issue. I have 4 bikes on the back of my trailer with no problems. I do have the rack secured so that it is one with the trailer, meaning no bouncing. I have a rear view camera on the back of the trailer and they do not move a bit.
In the pic it looks as if someone missed a step.
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 04-08-2013, 12:44 PM   #6
thebrakeman's Avatar
Some idiot lost a bike off a truck mounted rack from his sedan last year. I couldn't avoid it, and ran it over with both driver-side wheels. No damage to the Mounty, but it took out the front, bottom corner cap on the camper, and took at gouge out a brand new trailer tire. Could have been a lot worse.
When we take bikes anywhere, and they are not in the camper, they are securely mounted with the Thule roof rack. Worth every penny.
PS - If anyone must use some flimsy hanging rack system (even if it's a good name) at least put a cable lock thru the frames and attach to something solid. At least then the people behind you will have some more warning before the things come loose.
thebrakeman is offline   Reply With Quote
Old 04-08-2013, 01:24 PM   #7
mjones12's Avatar
Has anyone had any experience with the fold-down bike rack that is on some of the Surveyor models now? My new Surveyor 220 just happened to be equipped with one, but I don't take delivery until tomorrow. Just wondered if it is any good. Doubt we'll carry bikes on it. More like a grill and large outdoor fan. It goes almost the full width of the camper and folds down like a little deck. When the rack is up, the bottom section of the ladder must be folded up. I think I read that it holds 250 pounds. The spare tire seems to be attached to the bottom of the rack and folds down with it.
2018 Coachmen Apex 249 RBS
2010 Silverado LT 5.3 V8
The world is a great book, of which those who never stir from home
read only a page. - St. Augustine
mjones12 is offline   Reply With Quote
Old 04-09-2013, 12:30 PM   #8
No, but if it's stock, it's probably rigidly attached to the frame. I would still highly recommend you cable-lock thru the frames of the bikes, directly to the frame, or to something that is welded to the frame. The hitch/rack might be very strong, but maybe not so much the attachment points that actually hold the bikes to the rack.
