Old 05-13-2018, 07:06 PM   #21
Dan_M's Avatar
Originally Posted by Comanchecreek View Post
Sounds like your e-brake is dragging. Will give that kind of smell. I'll give you the benefit of the doubt that you are releasing it, but you may have a problem with the cables or the adjustment that is causing it to drag. The other possibility is that you have a seized rear brake caliper which is causing your brakes to get hot, causing your smell. When the caliper seizes the other side that is still working is the one that will get hot because it is doing all the braking. Would be aggravated when you tow.
Yea we always use the parking brake and release it. Habit from years of driving manuals.
We checked the cables and they look like they are doing that they are supposed to do. I may lift up the truck tomorrow to check.
If the parking brake was stuck then the smell would happen all the time, not only while towing.
2017 Prime Time Avenger ATI 27DBS
2016 Chevy Silverado 2500HD Gas
'17: 42
'18: 25
Dan_M is offline   Reply With Quote
Old 05-14-2018, 09:09 AM   #22
Wolverine 1945's Avatar
Originally Posted by Dan_M View Post
Thanks for the replies.
Nah, never dropped the spare. I can check pressure and fill it up without dropping so never had a need to do so.
I'll take the trailer out again tomorrow and check the temps of the differential pinion.
It's the darnest thing tho. The truck doesn't have that much miles on it. We did take it on long trips before (Georgia to Canada) pulling the camper without any smells/issues. Brought it to the dealer for oil change (it's free so might as well) and now the thing smells.
Thanks again.
Could it be the trailer and not the truck ???
Brakes on the trailer ???
GOOD LUCK !!!
Wolverine 1945 is offline   Reply With Quote
Old 05-14-2018, 11:17 AM   #23
Dan_M's Avatar
GOOD LUCK !!!
Thanks!
That is what I thought at first. Checked the trailer, no problem there. Bearings were packed back in January and we did about a 1000 miles since without issues. Checked the trailer hubs with a IR thermometer during my test run and temps are nominals, all wheels are +/-2 degrees.
'17: 42
'18: 25
Old 05-14-2018, 08:46 PM   #24
Sorry but I had to laugh at you topic title!!!
santarich is offline   Reply With Quote
Old 05-15-2018, 06:52 AM   #25
That is another place to look hey ???
Old 05-15-2018, 08:16 AM   #26
Dan_M's Avatar
My wife does make some banging but dangerous Belizean Habanero sauce. She hasn't in a while though.
'17: 42
'18: 25
Old 05-15-2018, 08:19 AM   #27
Sounds like a Front Door & Back Door Burner !!!
Old 05-17-2018, 08:19 AM   #28
Originally Posted by keegantimber View Post
I wouldnt think this would happen with a 2500....but here is a thought to consider....When I was towing with a 1500 I was getting a nasty gear oil smell from the rear differential. I believe I was darn near boiling the rear diff fluid....the fumes were coming out the diff vent. I noticed excess moisture around the vent nipple located at the end of the hose tied to the frame. I have since upgraded to a 2500...lol. If this is the case you might want to consider a performance finned differential cover which may assist in keeping the temperature down.
I had that exact issue with a Ram 1500. We had it rebuilt multiple times trying to fix it and finally gave up and bought a 2500.
2013 Rockwood 2109S
2010 Dodge Ram 1500 Crew Cab 4x4 Hemi
GearHd6 is offline   Reply With Quote
Old 05-17-2018, 08:36 AM   #29
onetonford's Avatar
You said you had oil change is it possible that they didn't seat the dipstick all the way down? I know they had some issues with them years ago when I had a GM truck they sent a new dipstick to replace original because it would push up and leak intermittently.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 05-20-2018, 04:53 PM   #30
Dan_M's Avatar
Thank all for the replies.
Checked everything we could and we couldn't find any possible issue. We went on with the trip.
We made it to natural bridge VA on our way to Connecticut without problems. The smell went away. More likely oil from road or somewhere on the exhaust.
We've been monitoring temperature closely and nothing is out the norm.
Again, thank you.
'17: 42
'18: 25
Old 05-20-2018, 05:25 PM   #31
I am glad you did not find any problem. I was reading this with interest since I have the 2015 version of your truck.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 05-22-2018, 05:24 PM   #32
This more than likely going to be the result of a leak at one of the hubs. Could just be loose or it could be a bad seal. Differential oil will be most obvious on the inside of the rear tires/wheels or disc brake. The smell is from oil on one of the rear disc rotors.
I replaced the right side seal on my '07 GMC 2500HD at about 50,000 miles. It had been leaking for a while prior, but like you, I was not able to isolate the source. Eventually, the leak became so bad that the inside of my right rear tire was fairly covered and even had diff fluid seeping out of my center hub cap.
Good news is that it's pretty easy fix. I was out of warranty and did it myself in about 2 hours.
Mike
2017 Palomini 181FBS Offroad Edition
2017 GMC Sierra 1500 All Terrain Crew Cab 4x4, 6.2 liter/8 speed.
LandPirate is offline   Reply With Quote
