Old 05-12-2018, 05:16 PM   #1
Dan_M's Avatar
Burnt smell from rear end
Hey all
On our last trip I have noticed a burnt rubber smell that comes and goes. It wasn't often so I thought it was someone else. But it followed us.
It seems only to happen when we tow. Never noticed it while not towing.
The smell doesn't smell like brakes. It's more of a burnt rubber smell.
I took the trailer out today and the smell came back briefly. I think it is coming from my rear end (nothing abnormal with the camper, all smells and temperature are good). I used a temp gun to get the wheels/brake temp and both rear wheels are the same. The differential is at 146F, ambient temperature out today was 90F.
Truck drive and stops fine. Nothing abnormal there either.
The truck is a 2016 Silverado 2500HD. Has 25k miles. Recently got an oil change but no other service.
The differential has some wet looking spots. (Picture attached).
We're leaving Friday for a 1000 miles trip so I'm a little worried about it.
Any ideas?
Thanks all !
DanClick image for larger version
2017 Prime Time Avenger ATI 27DBS
2016 Chevy Silverado 2500HD Gas
'17: 42
'18: 25
Dan_M is offline   Reply With Quote
Old 05-12-2018, 05:48 PM   #2
Two ideas:
Check the temperature of the pinion bearing in the front of the differential. It gets hot and can even start to glow when the differential fluid is low. It doesn't seem to leak around the diff housing though.
Check the differential breather and the wheel end of the axle if there is any indication of gear oil. Overfilling or a plugged diff breather can have it come out there.
TheGerman is offline   Reply With Quote
Old 05-12-2018, 07:15 PM   #3
Failure is my business
2Evil4U's Avatar
Have you ever dropped the spare tire? If it went back up slightly out of position, could it be very close to the exhaust pipe?
Current vehicle list: 17 RAM 3500 4x4 Cummins Aisin 4.10, 16 Flagstaff 832IKBS, 14 RAM 1500 4x4 Hemi 3.92 Bilstein 5100's Derale oil cooler, 97 F150 4x4 5.4L 275,000 miles, 80 Firebird Esprit Aussie Burnout Car https://youtu.be/v06VjII7HmE, 78 Harley Davidson FX 79,000 miles dad bought new, 71 El Camino ZZ3 TH400 12-Bolt, 37 Ford 3 window 502 Chevy dad built
Days Camped: 2016: 43, 2017: 83, 2018: 44, 2019: 4
2Evil4U is offline   Reply With Quote
Old 05-12-2018, 08:40 PM   #4
Dan_M's Avatar
Thanks for the replies.
Nah, never dropped the spare. I can check pressure and fill it up without dropping so never had a need to do so.
I'll take the trailer out again tomorrow and check the temps of the differential pinion.
It's the darnest thing tho. The truck doesn't have that much miles on it. We did take it on long trips before (Georgia to Canada) pulling the camper without any smells/issues. Brought it to the dealer for oil change (it's free so might as well) and now the thing smells.
Thanks again.
'17: 42
'18: 25
Old 05-12-2018, 08:53 PM   #5
+1. Several years ago a shop retracted my spare too close to the tail pipe and the heat charred the tread of the tire....
AZ Pete is offline   Reply With Quote
Old 05-12-2018, 09:00 PM   #6
Any chance the smell is spilled oil from the last service?
2017 Riverstone 38FB Legacy
2018 F450
LegacyFB38 is offline   Reply With Quote
Old 05-12-2018, 09:03 PM   #7
Dan_M's Avatar
thanks. I just went and checked it out and it looks good, no sign of melting on the tire. I'll check the temp on that too tomorrow when I take it out for a ride again. There is a separation between the exhaust pipe and the tire and that looks good as well.
'17: 42
'18: 25
Old 05-12-2018, 09:04 PM   #8
Dan_M's Avatar
The smell is definitely coming from the rear. The front/engine block doesn't smell burnt at all.
'17: 42
'18: 25
Old 05-12-2018, 09:06 PM   #9
Iwannacamp's Avatar
I assume you have checked the fluid level?
Another thing(besides the spare) are the rubber insulators that mount the exhaust....especially if it has been modified.
Diesel? Exhaust temps up when towing?
Maybe a fluid leaking on the exhaust that only shows when working the truck.
Parking brake dragging a bit?
All pretty cheap checks.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Old 05-13-2018, 12:37 PM   #10
Dan_M's Avatar
hey
The truck is stock, no exhaust modification. It's a gasoline but now that you mention it, the smell is extremely similar to the same smell our car makes when it is running regen.
I checked the differential fluid level and it's fine.
It could some thing road oil or something stuck on the muffler.. or something stupid like that.
I have a "honey-do" list today so I may not have a chance to go on another drive until later.
Thanks again all!
'17: 42
'18: 25
