Old 12-30-2012, 03:14 AM   #11
JohnF's Avatar
So how about this one?
10K Equalizer Adj Hitch - RVWholesalers.com RV Parts and Accessories
JohnF is offline   Reply With Quote
Old 12-30-2012, 08:18 AM   #12
MtnGuy's Avatar
Originally Posted by JohnF View Post
Much better choice. 1000 lb. spring bars may be a little stiff, but will work. The 600 lb. spring bars may be a better option, depending on if the maximum tongue weight can be kept under 600 lbs.
Old 12-30-2012, 08:22 AM   #13
PHS79's Avatar
This one here would be much better suited to your camper. 6K Equalizer Adj Hitch - RVWholesalers.com RV Parts and Accessories
TT-2013 Passport 3220BH
TV-2004 F150 FX4, not exactly stock...
nights camped:
with 2001 Kodiak K215: 2010-10, 2011-12
with 2012 Grey Wolf 26BH: 2012-19, 2013-24, 2014-11, 2015-6
with 2013 Passport: 2015-13, 2016-15 booked
PHS79 is offline   Reply With Quote
Old 12-30-2012, 09:40 AM   #14
JohnF's Avatar
Yes, the smaller would be better. The camper brochure shows a dry hitch weight of 377 lbs. Add the battery and propane. This particular camper has the bed in the front so I don't see too much more weight up front except for the through storage area. Hopefully I can keep it below 600 lbs. I probably should wait to order. I'll check with the dealer next week for his thoughts.
Thanks,
John
Old 12-30-2012, 10:46 AM   #15
Originally Posted by PHS79 View Post
Another option is to buy the Andersen WD hitch. It is total adjustable for weights up to 1400/14000 if I remember correctly. This is the hitch that I am running and I really like it, also I can move it to the next TT we get without having to worry if its too heavy or too light for the TT. Just another option, good luck.
On edit: Depending on what your tow vehicle is, it is possible that you may not even need a WD hitch. Our old Kodiak K215 had a loaded tongue weight of 500lbs +/- 20lbs depending how we loaded it, I towed it with my 04 F150 with no WD hitch and it towed great.
I'll second the Andersen WD hitch. It's the hitch I have now and I have had others. This hitch is clean, quick to connect, easy to use and makes no noise. You never get your hands dirty and it doesn't have to be disconnected for tight turns or backing. No sway, no problems.
Since it's relatively new to the market the dealer I bought my trailer from did not sell them. I ordered it on line and their service department installed it for me. The service man that brought my truck and trailer to the front of the dealership told me he had never towed anything so quiet (no snapping and popping while turning).
comfun1 is offline   Reply With Quote
