02-29-2016, 05:40 PM
#81
Originally Posted by 5er_tom
Coming out of the dark side! Good for you.
X2 and congratulations!
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
03-01-2016, 11:29 AM
#82
Update on truck, just my luck I put the Walmart DEF in tank on Friday and drive it first time on Saturday and check DEF comes on. Chevy says it's a sensor in the tank and tank has to be replaced. The truck that was bringing the part broke down, what a way to start DW retirement and first trip today
03-04-2016, 08:31 AM
#83
(Dry Huunday)
For those that use Peak DEF and don't know, here is the email on how you interpret the date code:
(The code used below was from a box that I bought from Sam's Club 2 weeks ago.)
Thank you for your email.
The product has a two year shelf life assuming it has been stored at 86 F or less. If it stored above 86 degrees, then it can be reduced down to six months.
Here is an example code that deciphers the batch code for diesel exhaust fluid.
Example Code |Method to Decipher
PB160071555 |PB = LOCATION
|16 = Year + 1 (2015)
|007 = Days remaining in year
|(Reverse Julian Date) December
|25th
|1555 = Batch Code
The first two letters or numbers can change depending on blend facility but the codes all translate the same based off of ISO standards.
Regards,
Peak Tech Services
Beau & Sue
FurKid Express
2015 Coachmen Catalina 303RLS
03-04-2016, 11:38 AM
#84
|25th
|1555 = Batch Code
Regards,
Peak Tech Services
Thank you - I ask how to read the date code at a auto store and the sales guy got the manager. The manager look over the box and told me that it doesn't expire and last for ever since it is mostly water. To say the least I didn't buy it and never shopped at that store again.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
03-04-2016, 11:44 AM
#85
Originally Posted by Ejs4029
Stopped in Walmart Last night and noticed they started selling SuperTech Blue DEF for $7.88 for 2.5 gallons...Sam's Club has the Peak Blue DEF for $10.99 for 2.5 gallons.
A local Travel America Truck Stop sells it at the pump for $2.85 per gallon so $7.13 for 2.5 gallons.
So I guess my question is all Blue DEF created equal ? My New Ram 2500 with the Cummins is almost at the half way mark on it's first tank so I am going to be filling it soon. I would imagine the easiest thing to do is go to the truck stop and just pump it or am I missing anything ?
Other posters have said that they pay more 'at the pump'. However, based on comparing to the above prices, I just paid $1.75 a gallon 'at the pump' at a local gas station that has 3 truck lanes. So, apparently cheaper, and dang sure more convenient. I was about out, and paid a total of $9.53 to fill it up.
03-04-2016, 11:55 AM
#86
(Dry Huunday)
You're welcome! I don't know why they (and other companies) don't just use a real date, but they don't!
I don't blame you about never shopping there again. Thats a crazy answer!
Beau & Sue
FurKid Express
03-08-2022, 04:50 PM
#87
Blue DEF date codes have changed in that they no longer start with the two-digit plant code. The new scheme is not found anywhere online that I could see.
Per a call to Old World Industries technical support line today, the first five digits are all you need:
22207 01249 CP7 7115
22 - 1 = 21 = year manufactured
365 - 207 = 158 = June 7 on the Julian calendar
So this product was manufactured 6/7/21 and is under one year old.
They reiterated there is no hard and fast rule about expiration because it all depends on storage temperature. The warmer it is, the shorter time it lasts. The colder it is, the longer it lasts. All within the specified storage temperature range which is -23F (5C) to 86F (30C).
"Storage" includes when it's in the engine of course.
Per their web site, freezing is OK. Both their storage container and DEF tanks are designed to allow expansion which is up to 7% in volume. DEF tanks have heaters to warm it up and make it ready for use.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
