Old 07-13-2016, 08:17 PM   #1
Buying our first TT and can we tow this
We've finally found the TT we like. Any thought on th Forest River Evo ats 22rb? We have a 2007 Ford F-150, V8, 4.6 engine ford says it can tow 6,600. We are taking a 1 year road trip around the US and parts of Canada. Will our truck tow this fine and is it a good starter TT?
miagigirl is offline   Reply With Quote
Old 07-13-2016, 08:30 PM   #2
crunchman12001's Avatar
Can you confirm model #, I could find the specs. How much does the unit weigh and what year?
2015 F-250 FX4
Old 07-13-2016, 08:42 PM   #3
I added a pic with the model number and info
Old 07-13-2016, 08:53 PM   #4
It's a 2017 and 5540 lbs
Old 07-13-2016, 08:54 PM   #5
Ugh! 2016
Old 07-13-2016, 09:36 PM   #6
KDHfan's Avatar
Just my opinion... But if that's the brochure weight... Or even the sticker weight... You have too much camper for your truck. The salesman might tell you "sure, you can tow that, no problem." While technically, you might be able to (but I think you'll be over your combined weight), you really shouldn't.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 07-13-2016, 09:50 PM   #7
I couldn't find any info on your TT either. If the 5540 lbs is the GVWR, you may be OK. GVWR is the maximum the TT can weigh with everything loaded, i.e. you never want to exceed this weight. So if it's the GVWR, that would give you about 17% margin to your Ford's towing limit.
However, you also need to worry about payload, which is usually the first thing to be exceeded. Open your Ford's drivers door and look at the sticker you find there. It will tell you how much weight you can add to your Ford. This is the payload. It does not include the driver, but it does include EVERYTHING else you may add. This includes the tongue weight of the TT and the weight of the hitch itself. (Weight distributing hitches, which you WILL need) can run 50-75 lbs.)
So now you need to figure tongue weight. I was unable to find any numbers on your model TT. So you'll need to ask what the tongue weight is. The tongue weight they give you will most likely NOT include a battery on the tongue OR the propane. So you'll need to add that weight to the tongue weight. Alternatively, you can figure about 15% of the GVWR number once you figure what it is.
Once you know your tongue weight, add the hitch weight and everything else you intend to add to the Ford. If this number is greater than the number on the drivers door sticker, you have a problem.
Note the biggest lie RV salesmen say: "Oh, a half ton pickup can tow this!" Not all half tons are created equal. My 2009 Silverado owners manual listed 99 (yes, 99!) permutations of engine, cab, bed, rear end gearing, etc. The tow capacity for these ranged from 4000 lbs to 12,000 lbs. So how can an RV salesman truthfully tell you that YOUR pickup can pull any specific TT?
Good luck.
2011 Traverse LT, 3.6L, FWD
Old 07-13-2016, 09:55 PM   #8
Engineer of Crazy Train
ChooChooMan74's Avatar
I am looking at the yellow sticker for a Evo 220RBS. Looks like this one is about 5500 off the factory. Going for a year, you will have a lot of cargo. The GVW of this unit is 7655.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183 (SOLD due to 2 years off work)
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 07-13-2016, 10:04 PM   #9
Miagigirl: To steal a phrase: "You're gonna need a bigger truck!"
Old 07-13-2016, 10:09 PM   #10
WFD
Sounds like you haven't yet committed to buying this trailer...looks like you have a choice to make....find a lighter trailer, or get a different truck.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
