Old 12-05-2015, 11:40 PM   #21
B and B's Avatar
Originally Posted by doc73 View Post
What does making the exhaust brake come on do?
Sent from my SAMSUNG-SM-G870A using Tapatalk
My exhaust brake comes on as well. It creates back pressure heating up the engine. It remains on while parked.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 12-06-2015, 12:04 AM   #22
Engineer of Crazy Train
ChooChooMan74's Avatar
My Jeep Liberty CRD has a Viscous pump with an electric clutch. When the parameters are met, it creates warm water and pumps directly to the heater core. Works great over 1000 RPM. Once it gets to temp, then it pumps engine coolant to the heater core.
From Green Diesel about the EcoD
For those that are not aware, the Ram ecodiesel is equipped with 3 PTC heaters in the HVAC system designed to provide quick cabin heat after starting the engine. A PTC is essentially a coil heating element in the air system ducts, similar to a hair dryer. All three PTC can pump out about 1000W.
The stock tune will idle at 1400 rpm is the HVAC requests the PCM to turn on the electrical heating elements (PTCs). For this to happen, it generally needs to be 50 F or colder outside and the coolant not warmed up. If you have the single-zone HVAC system, the temperature selector needs to be at maximum heat setting and the blower fan on at any level above zero. If you have the dual-zone HVAC it should only need the heat setting above the middle point and the blower on.
Granted, the 1000W PTC output is a bit low for the size of the cabin, this will help provide quicker heat than waiting for the coolant temps to rise.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 12-06-2015, 12:11 AM   #23
Small world, choochoo...now go back to the lostkjs forum ;-)
Drewd at lostkjs.com former Rhode Islander-Classical High School Class of '87
Skyliner is offline   Reply With Quote
Old 12-06-2015, 02:49 PM   #24
Hey. LostJeeps seems to be down. I am also on the Ram1500Diesel forum. One of the first to join (#60). Now, they are getting close to 7500 people who joined. Just got my EcoD after GDE had a tune finalized.
Locomotive Engineer
Old 12-06-2015, 02:51 PM   #25
Kenny kustom's Avatar
Heats up much, much faster.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 12-07-2015, 08:54 AM   #26
Jim34RL's Avatar
If you really want a warm truck and cab; installing an ESPAR Heater is the only way to go. Especially if you live in the land of the frozen tundra (north of the lower 48 states).
See this link from "Turbo Diesel Register. Com". A member added this to his truck and posted this write up.
http://www.turbodieselregister.com/t...lling-an-Espar
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
Old 12-07-2015, 09:32 AM   #27
Yea!!!
Best option out there!
2016 Sabre 36QBOK
diesel
