Old 10-13-2011, 09:34 AM   #11
Herk7769's Avatar
Originally Posted by Danielflading View Post
with my equalizer, I measure off of the TV wheel wells, the front should raise about 1/2 inch and the rear should drop about the same 1/2 inch
Dan,
While you are correct that the measurments should be from the ground to the fender well, I think you might have that backwards.
When correctly set (WD bars in place), the front should be closer to the ground and the back should rise showing load being transferred to the front from the back.
Name:	Equal-I-Zer Hitch installation.jpg
ID:	8460   Click image for larger version
Name:	How WD hitch Works.jpg
HAM CALLSIGN - KC3FFW
Old 10-13-2011, 10:39 AM   #12
BigDTx's Avatar
Originally Posted by herk7769 View Post
Dan,
Thanks Lou for clearing that up! It has been a while since I set mine up. Guess I rememeber it the other way.
BigDTx is offline   Reply With Quote
Old 10-13-2011, 01:55 PM   #13
lindy's Avatar
Danielflading, if the measurment for the front wheels raise about 1/2" you're still taking weight off your front axle and thus effecting your steering control.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-13-2011, 02:40 PM   #14
BigDTx's Avatar
yes I got that backwards and Lou cleared it up in the following post, thanks!
