Old 10-12-2011, 09:44 PM   #1
Calling all WDH Experts!
OK...Tried to find this as Im sure it's not the first time someone has asked this...
When using an Equalizer hitch (rated for 10,000lbs.) how much of the tongue / hitch weight does it transfter off the hitch, effectively reducing the hitch load?
Just took my RV to scales and had it weighed and it came out with the Trailer weighing in at 6100 lbs. and tongue at 1050 lbs. (put tongue jack on separate scale extended at same height as hitch).
Now the funny thing is that I don't have too much in the front storage compartment that weighs that much... The stripped down trailer off the line had a TW listed on the spec sheet of 382lbs. I figured 90lbs for the two 20lb propane tanks, 40lbs. for batt, 150lbs. worth of stuff (wood blocks, a few tools, case of bottled water, small carpet) and I guestimated 85lbs for Equalizer WDH- put's it near 750lbs. but nowhere near the 1050lb jaw drop at scales today.
In case youre wonderings, all this without any water in tanks.
So.. Im close to maxing out what Ford is stating on the hitch capacity (1130) on my F-150. Was wondering how much the Equalizer actually transfered off the tongue- make sense?
Appreciate any thoughts..
Thanks Forum!
Patrick Mahoney
2011 Palomino Thoroughbred Ultra Lite
Model T-273
2010 Ford F-150 Super Crew
Equalizer Hitch
pmahoney is offline   Reply With Quote
Old 10-12-2011, 10:11 PM   #2
Triguy's Avatar
Is this your trailer? If so, the dry hitch weight is 738lbs.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 10-12-2011, 10:25 PM   #3
This model is slightly different as it has different (slightly) configuration in front. Ours does not have the center entertainment console and I believe on this one, the cabinets in the front bedroom are larger..
Im reading the specs right off manufactors website.. 382lbs. is the "fresh off the line" Tongue Weight.
Patrick Mahoney
Model T-273
Equalizer Hitch
Old 10-12-2011, 10:28 PM   #4
Here's what I could find on RVGuide
2011 Palomino Thoroughbred Ultra-Lite T-273 Trailer : Reviews, Prices and Specs : RV Guide
Patrick Mahoney
Model T-273
Equalizer Hitch
Old 10-12-2011, 10:47 PM   #5
Triguy's Avatar
Well, sorry to say but that is not the manufacturer's website.
This one is Palomino's site.
I'll admit that it was the low dry TW that made me want to look at the site. I knew that trailer was something like 5,000 plus and 30' long. No way are they going to build it with a 384lbs dry hitch.
There is one thing that is strange, though. The TW on your trailer is 17% of the trailer weight. See what you can do to bring that down to 13-15%. That might help you with your truck.
Scott
2012 Shamrock 233S
Old 10-12-2011, 10:58 PM   #6
Yep... looked long at the website earlier this year.. Palomino has updated this unit a bit. In fact, when the 2011 T-273's first came out, they actually had two different models... One is the unit I have and the other had a large pack / play door option (and bunks) on the opposite side, flipping the bathroom to the drivers side.
I guess that's why you alway see those configuration disclaimers on the bottom of the manu's websites. Trust me... the 2011 unit I have from Palo is different, although when the center unit came out, I wished I would have waited.
At anyrate, yes the TW was too good to be true, and now my original question still remains regarding WDH's... do they actually transfer force / weight off the reciever hitch?????
Thanks....
Patrick Mahoney
Model T-273
Equalizer Hitch
Old 10-13-2011, 07:45 AM   #7
lindy's Avatar
Yes, that's what the WDH is suppose to do if set up properly. Some dealers believe it or not have no REAL idea how to set up a WDH. Equilizer has a great step by step instructions on PROPER set-up on their web site "equilizerhitch.com". When I bought my trl the dealer was way off on setting up the hitch. With their set-up they actually had unloaded weight off my front tires. One point not talked about in their set-up instructions is to measure the body height on both rear and front axles before hooking up. If properly set up there should be about an equal drop in the body height both front and rear, then you know that the hitch weight has been distributed along the whole TV's frame properly.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 10-13-2011, 08:07 AM   #8
The the force applied by 1,050 lbs on the receiver itself doesn't get distributed at all. Weight gets distributed, not force. In fact think of it this way, you could crank up the WDH so high that you could distribute all of the weight off of the rear axle. Does this leave a zero TW? Nope, the receiver still has a 1,050 lbs of force applied to it.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 10-13-2011, 08:21 AM   #9
Herk7769's Avatar
Really? This was not all that hard to find.
How much weight does a WD hitch actually distribute?
HAM CALLSIGN - KC3FFW
Old 10-13-2011, 09:15 AM   #10
BigDTx's Avatar
with my equalizer, I measure off of the TV wheel wells, the front should raise about 1/2 inch and the rear should drop about the same 1/2 inch
BigDTx is offline   Reply With Quote
