Old 04-07-2015, 01:37 PM   #1
wicked1's Avatar
Camco EZ-LIFT 48058 1000lbs WDH with Sway
Folks I have this WDH on my truck but the dealer never gave me the instructions, I have to modify the heigh of the sleeve and ball, they set it to 2" and it should be 4" so I have to move it up. Does anyone know the torque setting for the two bolts that hold the sleeve to the riser bar? I am guessing 150lbs with a torque wrench but I am going to pick up my new Roo 23IKSS and last thing I want to do is have it traveling along side me on I95Ö.
2016 F350 Supercew Short Box 6.7 PowerStroke Diesel
2013 Crusader 295RST Touring Edition
wicked1 is offline   Reply With Quote
Old 04-07-2015, 01:43 PM   #2
wicked1's Avatar
well called Camco, they said the bolts are 3/4" and have to both be torqued to 260 lbs, Yikes time to go buy a new Torque wrench as mine only goes up to 120
Old 04-07-2015, 08:28 PM   #3
2015 Puma 30rkss
porter4dmfd's Avatar
FYI if you do a Google search for EZlift there is a PDF of the Owner's Manual out there that I've referenced a couple times.
porter4dmfd is offline   Reply With Quote
sway
