Old 01-04-2015, 09:21 AM   #11
davel1971's Avatar
probably. I think any of the current SRW 1 tons are pretty capable trucks.
David & Lynn
Old 01-04-2015, 09:24 AM   #12
Originally Posted by donniedu View Post
At 15,500 GVWR the trailer is going to see 3000 or more pounds of pin weight. Adding a hitch and the already probably 3500 or so pounds on the rear end of the truck, I'm going to tell you that you will likely be overloaded.
How do you know what the truck weighs unloaded on the back wheels to calculate this?
matcheson is offline   Reply With Quote
Old 01-04-2015, 09:28 AM   #13
davel1971's Avatar
you don't need to know. You need to know payload
David & Lynn
Old 01-04-2015, 09:47 AM   #14
camper1999's Avatar
I tow a Silverback with a 2500hd diesel. You should have not problem with a 3500 with any of the silverbacks
2011 GMC 2500HD Diesel
Old 01-04-2015, 10:04 AM   #15
davel1971's Avatar
actually towing isn't the issue. You are probably over payload like most 3/4 ton trucks are
David & Lynn
Old 01-04-2015, 10:11 AM   #16
mcnabbwr's Avatar
So is it fair to say a Ram 3500 CC SB SRW 4WD 6.7L I-6 TD 16,900# (a6,k)
would do the job? Or should I be looking for more GAWR on the rear?
I'm trying to avoid a dually if possible as will be using as main car also.
If you go with any of the big 3 one ton SRW with a diesel you will be fine. You do not need a dually.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 01-04-2015, 11:58 AM   #17
camper1999's Avatar
Nope I am within the payload of my truck.
Old 01-04-2015, 12:25 PM   #18
Payload for a 14-15 Ram 3500 SRW CCSB CTD is 4000lbs+. 11,700lb GVW. Plenty for any Silverback IMO. Jump up to a DRW and the payload goes to 5740lbs. Way overkill.
FWIW I'd tow most SB's with my 2500 CTD. I use the RAWR anyway. If I was buying new to go with a predetermined 5er then I'd def go 3500. For now I'll just make do with what I have.
goduc is offline   Reply With Quote
Old 01-04-2015, 12:33 PM   #19
davel1971's Avatar
Originally Posted by goduc View Post
Payload for a 14-15 Ram 3500 SRW CCSB CTD is 4000lbs+. 11,700lb GVW. Plenty for any Silverback IMO. .
almost identical specs for GM, Ford probably close too, but haven't looked. Just pick what flavor you like and you will be fine
David & Lynn
Old 01-04-2015, 12:36 PM   #20
Couldn't agree more. Find the one that has the most comfy seats and go for it.
