Old 01-07-2015, 01:53 PM   #41
Your discretion is the better part of valor. You made a wise choice.
Bob & Sharon, '18 Berkshire 34QS, 2018 Jeep Cherokee.
btritschler1437 is offline   Reply With Quote
Old 01-08-2015, 09:06 AM   #42
camper1999's Avatar
Originally Posted by camper1999 View Post
My 2011 GMC 2500 HD diesel has been a great truck. It has a payload of 3100 pounds. You actually can increase the payload of that year because the engine,trans,rear axle, and frame is the same as the 3500. You can add a leaf in the back or other suspension enhancement if you need it.
I must go to different places around town. I have had a dually, a suburban, and srw pick up. The dually a good some of the time was an issue parking. That is why I went back to srw. We travel with another couple that have a dually and they always suggest we take our truck. But a dually hands down is a cool truck.
2011 GMC 2500HD Diesel
Old 01-08-2015, 09:34 AM   #43
Toy-aholic
interesting....maybe the measurements in PA, NJ, MD & VA are different than others but in those states I have never not fit between the white lines in parking lots....or I have a narrow dually
2005 GMC Sierra 3500 SLT DRW 6.6 D/A
2013 Crusader 335BHS TE
EXGMTech is offline   Reply With Quote
Old 01-08-2015, 10:23 AM   #44
Well it's too late now, so I'll let you know how it goes. I have had to ensure I stay in the center of lanes, you have to be alert on some narrow back roads. But i'm sure I'll get used to it. As for parking so far the only issue is the length, not the width.
2015 Silverback 35QB4
2011 Ford F-350 6.7TD King Ranch 4WD DRW
matcheson is offline   Reply With Quote
Old 01-08-2015, 10:48 AM   #45
camper1999's Avatar
I never said it would not fit. http://www.chronofhorse.com/forum/ar.../t-174309.html
Old 01-08-2015, 11:35 AM   #46
Mddle of the Rd Extremist
MeepMeep's Avatar
I'm thinking I like your narrow dually concept - got a feeling that I may have one too cuz I've never had it not fit...
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 01-08-2015, 02:11 PM   #47
mr dually's Avatar
Do you already have the truck? or are you truck shopping? If I already had the srw 3500 I would go ahead and tow the trailer without another thought the silverback is a mid level fiver and should not be way over weight with a srw 1ton. There are guys pulling 40ft trailers that weigh some insane numbers with srw trucks, doesn't make it ideal or right but they do it.
If you are truck SHOPPING I would get the dually and be done buying trucks.
03 Fleetwood 31g LS
06 Chevy Gas Dually
07 Yamaha golf cart
Looking to purchase a Georgetown 364 ts Mh in the next couple of years.
mr dually is offline   Reply With Quote
Old 01-08-2015, 07:31 PM   #48
I had a 08 2500 6.6L 2 wheel drive and pull my 40'er at 15k. The tuck pulled the weight just fine. I now have 10 3500 with dual wheels. The only reason I switched trucks is to get a newer model and I will be getting a bigger camper one day.
10 Chevy Silverado 3500 CrewCab
6.6L Duramax with EFI Live Tuner with 5 levels
560hp 958 Max torque 3:73 gears
2015 Crusader 351REQ
cajun225 is offline   Reply With Quote
Old 01-08-2015, 08:30 PM   #49
ferguson65's Avatar
Exactly. Wheelbase and length make it harder to park than width. So long as you back into spots and have enough room in the aisle to get out you're set. Duals haven't stopped me from parking anywhere I originally intended to.
2013 F350 dually
2015 Palomino Puma 351THSS Premier Edition
2015 Nights camped 15
2016 Nights camped 5
ferguson65 is offline   Reply With Quote
Old 01-08-2015, 08:56 PM   #50
asquared's Avatar
Interesting. I was always afraid of a dually for width. Sounds like the issues are ones I'm already adjusted to.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
