Old 06-11-2013, 02:09 PM   #1
BandJCarm's Avatar
Can Chevy foldable mirrors be tightened?
2006 Chevy 1/2 ton. Has the fold-in mirrors, black plastic outside, bubble looking. Look like this:
1999-2007 Chevy Silverado Side View Mirrors - CIPA 27376 - CIPA Replacement Side View Mirrors
When towing the new TT home last week, put on Walmart mirror extensions. My regular mirrors are apparently so loose that the wind blew them every few seconds to the fully folded-in position!!!
I know this can surely be done at the dealer, or a shop, but is there a way I can easily tighten these mirrors so they don't blow in? I took those extensions back and got some better ones, slide on.......but I think I'll have the same problem as long as my regular mirrors are so loose.
Ideas?
BandJCarm is offline   Reply With Quote
Old 06-11-2013, 02:31 PM   #2
TURBS's Avatar
Ideas?
Yes if I remember correctly the mirror has to come off to do it.
Old 06-11-2013, 02:32 PM   #3
TURBS's Avatar
I would recommend just doing this....
2005 silverado towing mirror install.
Old 06-11-2013, 03:23 PM   #4
Camper Less Camping
Cajun Po-Boy's Avatar
Isn't there a plastic triangle shape cover on the inside door across from ac dash vent that you pop off and it exposes three hex bolts that you can tighten mirror down?
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 06-11-2013, 03:31 PM   #5
OP said it was the folding mechanism that was loose from what I gathered, not the mirror mount itself.
Old 06-11-2013, 03:46 PM   #6
TURBS's Avatar
I don't believe triangle piece will allow you to access the tension if it has one....
Can't remember.
Old 06-11-2013, 03:47 PM   #7
TURBS's Avatar
I was pretty sure I seen a tensioner in my oem mirrors when I swapped them for the towing mirrors.
But as I said I can't remember.
There may be no tension adjustment and mirror replacements are in order.
Old 06-11-2013, 04:09 PM   #8
I've got a like new set for sale cheap that I took off when I put on factory power extend tow mirrors 4 yrs ago.
Old 06-11-2013, 05:18 PM   #9
BandJCarm's Avatar
Took it to a body shop I know. They said these are not able to be tightened that way. They have plastic teeth/gears and those are stripped. Have to be replaced.
So I ordered the replacement retractable ones.
This thing is costing me a mint!!!!!
Old 06-11-2013, 05:21 PM   #10
TURBS's Avatar
Like the ones I linked to ?
