04-29-2016, 04:11 PM
Can I add sway bars to existing WDH setup?
I purchased a 2008 Rockwood Roo 23SS recently and it came with a WDH setup already installed. My questions is, is there a sway bar product I can purchase that can be installed (added to) my existing WDH setup? Or do WDH/sway bar setups come as an all in one package only?
Thanks in advance.
2013 Toyota Tundra Platinum 5.7 L V8 4x4
Husky Quest Brake Controller
Husky Sway Control Bar (RH)
Progressive Industries EMS-HW30C
04-29-2016, 04:17 PM
Yes you can easy if it has the hole on the wdh for the ball that it hooks to. If it does not have the hole a plate can be welded on.
2019.5 Rockwood 2509S
04-29-2016, 04:19 PM
Can you post a pic of the WDH? Different units take different sway controls, but Todd probably has it right.
Gotta go campin!
04-29-2016, 04:22 PM
What is the make and model of your WDH?
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
04-29-2016, 04:23 PM
I pick up the unit in 2 weeks, I will definitely post a photo at that point. Thanks Bama.
04-29-2016, 04:25 PM
I don't get the unit for 2 weeks so I am not sure at this point. I will resurrect the thread once I know. Thanks Flybob.
04-29-2016, 05:58 PM
Thanks in advance.
Basic old-tech WDHs have add-on friction antisway bars.
Newer tech WDHs have integrated sway control and have no separate sway bars.
I tow my 2007 Roo 23SS with the Equal-i-zer 4pt WDH.
04-30-2016, 11:49 AM
Thanks in advance.
There are a few good friction type anti sway devices or more accurately this are one or two that are branded by 10 different manufacturers. As stated, your head should have a little hole on a on either side of the main ball where you attach the smaller ball for the anti sway device. They work well, as you set them up properly before you hit the road. I pull a 9500lb Wildcat and it's what I use and works very well to control sway. Here is a link to Curts sight.
Sway Control | Trailer Sway | Weight Distribution
Cheers
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2014 57 nights.2015 116 nights .2016 96 nights .2017 72 nights. 2018 157 nights. 2019 52nights.2020/21 118 nights. 2022 115nights
04-30-2016, 05:22 PM
If the WDH system coming with your new trailer is an Equalizer, then you do not need to add an anti-sway accessory, friction-type feature. The weight distribution arms on the Equalizer also provide the anti-sway friction needed to prevent fish-tailing. We've used the same system for more than 20 years.
05-03-2016, 10:41 AM
Insert witty title here
Here's mine.
Sent from my SM-G900V using Tapatalk
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
05-03-2016, 10:57 AM
There are several wdh units that have built-in sway control including the Blue Ox Swaypro of which I'm familiar. I highly recommend you insist on purchasing a wdh with built-in sway control. One of the biggest disadvantages to using a wdh with an added sway bar is when backing...the sway bar must be removed. Backing with built-in sway units is not a problem. You'll wish you had built-in after bending the first sway bar...
Good luck and happy camping!
2016 Microlite 21DS
2014 Ram 1500 QC 6 cyl. 8 spd.
Blue Ox SwayPro
05-03-2016, 03:51 PM
Sorry, but this is not correct. I used a friction sway controller for 7 seasons, and never once did I remove it just to back in, and it was never damaged.
The forces involved when moving forward or rearward are identical. The only time something is going to be damaged is if you back into an extreme jackknife, and you bottom out the 2 parts of the unit within each other.
For this reason, the instructions tell you to use caution when backing, and know your limits in a jackknife. As an option, you MAY remove the controller. But removing is certainly not required.
05-03-2016, 06:23 PM
I stand corrected...my apologies. My statement was based upon the experiences of others who have had to replace their sway bars because they, in their words, "forgot to remove it before backing". Sounds like they may have approached a jackknife situation as mentioned.
With proper care, sounds like sway bars are no problem. Then again, no sway bars are definitely no problem if using a wdh with sway control engineered in.
2016 Microlite 21DS
Blue Ox SwayPro
05-03-2016, 06:30 PM
It can go both ways too. I bent the ball mount on my frame the first time I used it....going forward. Tight U turn. I've always taken mine off since then because 90% of my actual backing involves fairly tight turns to put it in position. I just don't take the chance. Now...on the WDH I just bought, I went ahead and just got built in sway for one less thing to take off.
05-03-2016, 06:46 PM
Canadian Member
Here is a video showing how to hitch up a typical WDH that has separate, add-on sway control arms.
Here is a video for the Equal-i-zer 4 point hitch. The hitch/unhitch demo starts at 6:10
05-04-2016, 04:09 AM
My setup is identical to the first video. The only thing I do slightly differently is that once the hitch is mounted on the ball, I actually have to use the tongue jack to lift the rear of my truck up some so there is enough slack to attach the WDH chains.
06-14-2016, 03:53 PM
Thanks everyone for the responses. As I mentioned I purchased this trailer used as a private sale so I do not have the option to get a WDH with sway control added on.
This is the hitch that came with the trailer.
Based on your photos and videos it seems obvious now that the small hole is for the sway bar. I have ordered a Husky brand bar from Costco and I think this will end up working perfectly.
I will likely have questions during the install process but thought I would update my progress to date.
06-14-2016, 04:07 PM
I purchased a second second hand e2 Fastway hitch w/1000lb round bars (2 point friction version of the Equalizer 4pt) for $100. On this one, the previous owner welded on a tab to the head for a conventional friction sway control device. (He was towing a 35ft tri-axle Airstream with a previous gen Chevy 1500...)
I decide to try it out, but had to redrill the hole for the small ball as it was way off on dimensions.
Result, absolutely no change in pulling, either with friction bar cranked down tight or loose.
I can still feel a small push/pull wiggle when semis or high speed vehicles pass me. Oh well, guess the e2 does just fine on its own. I have never actually had sway.
2021 Ram 1500 Big Horn LvL2 Quad Cab 4x4 5.7L 3.92
Trailer Steering and Integrated Trailer TPMS
GVWR: 7100
GAWRF: 3900 GAWRR: 4100 GCWR: 17,000
Payload Sticker: 1,867 lbs Tow Capacity: 11,767 lbs
Towing a nice 5th wheel near you
06-17-2016, 01:50 PM
A dedicated anti-sway bar provides much more sway control than the WD setups with sway control built in. It depends on your setup (trailer size and weight being the biggest factors) whether or not you need one.
The key to the anti-sway bars is to really crank them tight.
I use both, a WD with sway control and an anti-sway bar.
06-17-2016, 02:31 PM
Here's mine.
Sent from my iPad using Tapatalk
