Old 01-12-2014, 07:59 AM   #1
blkcorvair's Avatar
Can I beat the Sliding hitch vs fixed hitch Thread to death again?
Newbie here. Been lurking, using the search function and seasrching the web. Ive read countless hours of threads on weather I need a sliding hitch or not.
Heres the problem. I have a f-250 6-3/4 bed and I just ordred a new Crusader trailer. I almost bought a superglide hitch and while I have heard how great they are, I dont think I can deal with the size a weight of this thing.
I'd like to pull the trigger and get a standard fixed reese 20k hitch. Its alittle over 100 lbs so I can handle remove and install easily. I dont have want to leave a hitch hanging from the pin box and dont want to have to get any winch lift system.
I'd like to hear from people that either are using just a fixed hitch in thier shortbed and if they have had any real problems or those who have a manual slider and have never used it or found they didnt need too?
blkcorvair is offline   Reply With Quote
Old 01-12-2014, 08:07 AM   #2
Twisty's Avatar
I have an F350 CCSB and I will buy an auto slider when we get a fiver.
If I need it only once in 26 years it will be worth it.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 01-12-2014, 08:12 AM   #3
iceblaze580's Avatar
When I had a short box truck I had a slider hitch I had to use it a few times I still have the slider hitch in my new truck witch is a long box if I were you I would get the sliding hitch I would rather have a slider hitch and never use it then not have it and need one
iceblaze580 is offline   Reply With Quote
Old 01-12-2014, 08:35 AM   #4
blkcorvair's Avatar
I keep hearing that the manual slider hitches are noisy, and the one when people finally get around to using them they dont simily slide, but instead you have to jack down the trailer get the weight off and then slide them back. That doesnt seem worth it to me. I would think taking a little longer to back into that spot wpould be easier than all that. For that reason I was leaning towards the superglide. But at 200lbs Id have to make sure someone is around to help get it out of the truck or use a forklift. Not the eaiest when I want to run and go pick something up and this thing is stuck in the back of the truck. Plus the superglide is real big and since it is always moving I have to be real careful not to put anytghing around the hitch like a cooler or firewood.
Old 01-12-2014, 08:46 AM   #5
I've always kept my slider rails lubed and move the hitch every now and then I can still slide mine back and forth by hand when the 5er is not connected
Old 01-12-2014, 08:46 AM   #6
another_newfie's Avatar
I have a 295RST Crusader and a F-150HD with a 6/5 bed. I went with a Reese Manual 16K slider. I can easily pop the hitch head and take it out in 2 pieces. Not too bad to man handle at all. I've yet to have to use the slider function but it is there should I ever need to.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 01-12-2014, 08:52 AM   #7
Hi,
I'll throw one more possibility into the mix I didn't want the weight or the cost of a slider. Ended up with the Reese R16 and a Sidewinder. That was about 10,000 miles ago - it works great for us. Here are some pics and info: Towing a 5th Wheel | Small Home - Big Yard
SmallHomeBigYard.com Blog
2015 F-150 EB, Supercrew
2012 Wildcat 241RLX
Reese R16 & Sidewinder hitch
Days in the RV - 2013: 91; 2014: 86; 2015: 116
ColoradoKampers is offline   Reply With Quote
Old 01-12-2014, 09:03 AM   #8
dcheatwood's Avatar
I have a 2010 tundra DC with 6.5' bed. Installed Reese 16k slider for my wildcat fiver, even after being told I wouldn't need it. Being a newby, I didn't want to risk it. I now tow a rockwood fiver and have never needed the slider with either. I think front cap shape played a lot in me not needing it with the wildcat and the rockwood has a Reese revolution (sidewinder).
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
dcheatwood is online now   Reply With Quote
Old 01-12-2014, 09:07 AM   #9
slide5r4fun's Avatar
We chose the Pullrite hitch with removable rails so it can be completely removed from the bed when not in use. I can't quite handle the hitch removal by myself but still have a college student around to help with that task. If you don't have some extra muscle around to lend a quick hand you might want to look at other options that might be lighter. B&W makes a slider that some forum members speak highly of but I have no idea how much the hitch weighs. As for hauling stuff in the bed with our Pullrite hitch, we do it all the time. Just make sure the slide can pivot freely and all other areas are safe to use. We use bungee straps to secure ice chest/firewood/portable dump tank while travelling. Zero problems.
Kevin & Janine
2006 Dodge 2500 Megacab CTD 2WD
2012 Palomino Sabre 32RCTS
Pullrite Superglide 16K Hitch
slide5r4fun is online now   Reply With Quote
Old 01-12-2014, 09:09 AM   #10
transamz9's Avatar
I don't have a slider hitch and have pulled 3 different 5er's with it (one of them is the older square front end) and have never had a problem. Like others have said, if you feel you have to have a slider then most of the hitches no days will come out of the truck in two parts making it lighter to deal with. I usually take my non-slider out in two pieces just to make it easier to handle.
2005 Ram 5.9 AT SB QC (Retired)
2010 Ram 6.7 G56 QC CC Aluminum flat/Leveled (Sold)
2008 Nitro Z9 towed by a 2015 Sanibel 3601 towed by a 2013 Ram 3500 SRW CCSB Cummins
2006 EZ GO 6" lift
transamz9 is offline   Reply With Quote
hitch
