Old 02-09-2014, 03:58 PM   #11
Broke and happy
bobfa's Avatar
Airbags for my 2013 F250 6.7 Crew 4x4 Kingranch fixed the sag. I had 2200 pin weight on scale. Was sagging bad but 50 psi on a pair of Firestone 5000 lb air bags fixed that problem.
bobfa is offline   Reply With Quote
Old 02-10-2014, 10:09 PM   #12
Originally Posted by Oakman View Post
I"m questioning the GVWR of his truck. 10000 pounds seems too little for an F350. My three quarter ton F250 crew cab diesel 4X4 has a GVWR of 10000 pounds.
I agree. This sounds like a case where the GVWR is governed by the registration in the state to avoid commercial plate requirements (like Pennsylvania). In fact, I learned after buying my truck that I had the option of order it with a lower GVWR placard.
When I renewed my entirely residential/non-commercial registration for the year, I was informed that I'm supposed to be doing/having done some kind of yearly preventative maintenance inspection:
Maryland Motor Carrier Frequently Asked Questions
This is a reminder to myself- I really need to call MDOT and find out if it applies to non-commercial folks such as myself.
2013 Sabre 36QBOK pulled by a 2012 Ram 3500 DRW
Blogs: Learn to RV & Personal Fulltiming Adventure
Towing Calculators: Towing Planner
Old 02-11-2014, 12:08 AM   #13
leencharlotte's Avatar
I have the same truck as op with 20" tires but my gvwr is 11.500 and my axles have same rating. Are you positive on the gvwr? My fifth wheel pin weighed with gear not loaded for camping is 2700. I have close to a 2" drop and virtually no lift in front. Handles well!
2011 F-350 SRW Lariat FX4
2014 Sandpiper 365SAQB
leencharlotte is offline   Reply With Quote
