Old 02-09-2014, 11:51 AM   #1
Can i hold this pin wt.
I have an 2011 F-350 CC 4x4 6.7 Diesel. Door jam says Front Gawr 5600 lbs Rear Gawr 7000 Gawr of 10000. Tires are 20 inch w. a load rating of 3750 lbs. each We are looking to buy a Columbus 320RS w. a hitch wt. of 2015 lbs. unloaded so im guessing loaded would be around 2400 lbs. UVW of Fifth wheel 10,604 and Gvwr 14,015 im a little worried about the pin wt. Thanks
Sodapopman is offline   Reply With Quote
Old 02-09-2014, 12:01 PM   #2
iceblaze580's Avatar
You should be ok I have a columbus 325 I was pulling with a dodge ram 3500 SRW 2 wheel drive
iceblaze580 is offline   Reply With Quote
Old 02-09-2014, 12:19 PM   #3
fonzie's Avatar
Have a look at the 2011 Ford towing guide.....
http://www.fleet.ford.com/resources/...ng%20Guide.pdf
Fonzie
Old 02-09-2014, 12:20 PM   #4
Whats your payload availability?
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 02-09-2014, 12:25 PM   #5
Fulltime family RVer
There are 2 calculators on my site that should help:
http://www.towingplanner.com
1) calculating available payload by estimating weights and working backwards from your available payload doorjamb sticker
2) estimating loaded/actual pin weight based on dry weights
Old 02-09-2014, 01:19 PM   #6
Todouble's Avatar
#2400 lb pin is no problem for your truck. I have about a 2300lb pin in my 250 and it tows like a dream! Have fun camping!
Todouble is offline   Reply With Quote
Old 02-09-2014, 02:10 PM   #7
Oakman's Avatar
Your one ton diesel truck will have no issues with that Columbus fifth wheel. Buy it and enjoy it.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-09-2014, 02:30 PM   #8
The only way you are going to know is to load the truck with everything, driver, passengers, fuel, hitch, dogs, firewood and head to a scale.
I'm guessing you will find your truck weighs some where around 8,000 lbs. With a GVWR of 10,000 - 8,000 = 2,000 available pin weight.
My truck has the same GVWR as yours. I have weighed mine and was surprised at how little pin wgt. was left.
John And Mary
2013 XLR 27 HFS
2013 CHEVROLET 2500 6.6 DURAMAX
Nights Camped 2012 (7) 2013 (33) 2014 (27) 2015 (34) 2016 (4)
Kaboom is offline   Reply With Quote
Old 02-09-2014, 03:06 PM   #9
Oakman's Avatar
I"m questioning the GVWR of his truck. 10000 pounds seems too little for an F350. My three quarter ton F250 crew cab diesel 4X4 has a GVWR of 10000 pounds.
Bob and Joyce
ATU Local 788
Old 02-09-2014, 03:43 PM   #10
jonrjen's Avatar
You all make in question the GVWR on my 2013 F350 FX4 6.7 3:73. My sticker for the GVWR is 14,000. I have 17" tires on my F350.
2013 Ford F350 FX4 4x4 PSD
2013 Wildcat 353LS
2015 Day/Nights Camped 5
2014 Day/Nights Camped 29
jonrjen is offline   Reply With Quote
