Old 02-08-2016, 11:19 AM   #11
I have a f150 3.7 eng and I tow my grey wolf 26 RR and it weight 6000 just fine do you a towing package on your truck
gil56 is offline   Reply With Quote
Old 02-08-2016, 11:22 AM   #12
Who Dares, Wins
doc73's Avatar
That's correct...The third weight lets you see that amount being transferred to the front axle. Helps you make sure you are adjusted the best possible way for optimal weight transfer.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-08-2016, 11:53 AM   #13
For some of the more experienced towers on here...Does the 3.31 rear end seem like a high ratio for towing? I've always had 3.92 or 4.11 in my trucks since owning a camper. Could that be what is causing it to "struggle" to stay at 65?
2016 Flagstaff 23LB
howie70 is offline   Reply With Quote
Old 02-08-2016, 01:21 PM   #14
RVPP's Avatar
I have a 2013, F-150, V6, non ecoboost. Our TT comes in a little under 3800, dry. Tows fine! Make sure you have the tow/haul button in and away you go.
RVPP is offline   Reply With Quote
Old 02-08-2016, 01:53 PM   #15
Canadian Contingent
Dogpatch's Avatar
Having just sold my 2013 F150 EB, I can attest that they do have power and can pull, however, they just don't have the torque to pull at highway speeds up hill with a load near capacity.
It ain't no race car, but if you take your time, it'll get there.
3:31's are definitely more of a highway gear.
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 02-08-2016, 05:24 PM   #16
Towing/brakes
We have a 2011 F150 and a TT that weighes in at 5300 lbs. According to our truck numbers we are good for up to 9000 lbs. We do use the tow/haul button which makes sure you get maximum rpm value in a shift. A friend of ours manages a Ford dealership and recommended a factory brake controller as it works better with computer in truck with trailer brakes.... if you are unsure about what your truck can handle ask the local Ford dealer. Happy trails to you!
KamperKen1967 is offline   Reply With Quote
Old 02-08-2016, 05:28 PM   #17
Off the top of my head you're okay. But, check the 2013 Ford Towing Guide online, find your truck and get its towing specs. If you don't have the tow package I strongly recommend you add at least a transmission cooler. I assume you know already you need a weight distributing hitch. Consider also that you should upgrade your truck tires to load range E.
phillyg is offline   Reply With Quote
Old 02-08-2016, 05:34 PM   #18
asquared's Avatar
Originally Posted by emm-dee View Post
If one always tows with a WD hitch why is weighing the TV without it relevant?
The weight without wdh gives you an easy way to calculate true tongue weight and true trailer weight without the wdh messing with the calculations. Remember the wdh transfers weight to the front axle and back to the trailer.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-08-2016, 08:55 PM   #19
Thanks everyone for all the feedback. Feeling better about it already. My truck had the towing package already (trailer brake, receiver hitch and 7 way plug). I doubt I have the transmission cooler but I'll have to look at the paperwork from when I bought it. I did get a weight distributing hitch installed and I use the tow/haul mode so I guess that's all I can do other than upgrading the tires and taking it to a weight station. Thanks again for all the input and this site is already proving very valuable for a first timer.
2016 Vibe 250BHS
2015 Chevy Silverado 2500 HD w/ 6.0L gas engine
Husky Center Line TS Hitch.
LJS1211 is offline   Reply With Quote
Old 02-08-2016, 09:27 PM   #20
OntarioFireFighter's Avatar
I just traded in a '13 F150 5.0... We've got a bit bigger trailer - 28BH, about 8000# rolling and loaded, I figure.
Truck handled it fine - knew it was there, but would cruise highway speed fine. Air up the rear tires, and good to go. WDH with sway (equalizer e2) all the time.
Put on about 3500 km last year; so about 2000 miles, I guess?
Having a fairly short wheelbase, compared the the trailer length, gusty cross-winds were a bit white-knuckle sometimes.
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
2013, f150
