Old 02-07-2016, 10:59 PM   #1
Can my 2013 F150 tow this safely
We just bought our first travel trailer and I have a few concerns after bringing it home from the dealership (and then right back for some warranty work). I have a 2013 F150 Supercrew (145" wheelbase) with the 5.0 V8 and 3.31 rear end. Our new trailer is a 2016 Vibe 250BHS and the hitch weight is 611lbs and the UVW is 4800lbs based on what the manufacturer says. The truck seems to do fine however I can definitely hear the engine working a little harder on hills and sometimes it struggled to stay at 65 mph on the highway. Of course the dealer says this is normal but really wanted to hear from some of you guys who have been doing this a lot longer than me and who have more experience. Thanks in advance for your input.
LJS1211 is offline   Reply With Quote
Old 02-07-2016, 11:03 PM   #2
Here is the sticker from my truck if it helps.
2016 Vibe 250BHS
2015 Chevy Silverado 2500 HD w/ 6.0L gas engine
Husky Center Line TS Hitch.
Old 02-07-2016, 11:32 PM   #3
asquared's Avatar
It is normal to hear the engine working on the hills. Lock out overdrive to help you out. Do you have the tow package with a heavy duty transmission cooler?
Looking at the numbers, you are likely within specs for your truck. You have a payload of 1638 and a likely loaded trailer weight of around 6300 lbs with a likely loaded hitch weight of around 800-950 lbs. Depending on how you load both truck and trailer you might be at max or a little over or under on payload. Only way to truly know is a trip to the scales. You want unloaded truck weight with separate rear and front axle weights (front axle on scale pad 1, trailer axle on scale pad 2). Then get a weight with truck as in 1st weigh but trailer with wdh hooked up and trailer axles on scale pad 3. Then get a third weight of truck and trailer no wdh truck on scale pads 1 and 2, trailer axles on scale pad 3. Make sure both truck and trailer are loaded like you would g or camping with all pets, occupants, gear etc and a full tank of fuel. This takes the guesswork out of it.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 02-07-2016, 11:34 PM   #4
CWSWine's Avatar
Seem like you are ok but there is a lot of variables when trying to figure out weighs. I made a lot assumptions but you can make them closer to true weights.
Towing Calculator based on Truck&#39;s Payload/CCC - Towing Planner
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 02-08-2016, 12:10 AM   #5
I go RV'ing not Camping
jgourlie's Avatar
The max speed your trailer tires are rated for is 65mph...so not being able to keep speed of 65mph is "a ok"
312QBUD Owners Thread
2015 Wildwood Heritage Glen 312QBUD
2000 Chev 2500 Extended Cab 6 Liter
1400lbs Equal-i-zer Hitch
jgourlie is offline   Reply With Quote
Old 02-08-2016, 05:33 AM   #6
We have similar setups. My payload is 150 pounds higher. I have the EB and 157" weelbase. My dry weight on trailer is 5300 pounds. I've been to a scale, and I am 100 pounds over payload when ready for a trip. Family of 4 and dog.
The truck is stable, and I'm comfortable being within a few hundred pounds of the limits. I'm a cautious driver, my interstate speed is 58mph.
That gives a reference point, but it is all guessing without going to a scale loaded up.
2013 F150, EBoost,4x4,CC, MaxTow
2015 Surveyor 245BHS
tragusa3 is offline   Reply With Quote
Old 02-08-2016, 06:27 AM   #7
Fred H.'s Avatar
Just keep it in mind that you need much more room to stop. Give yourself plenty of room from the guy in front of you. Even with the brakes on the trailer, it's going to take much more to come to a complete stop than with no trailer.
Be safe and enjoy!
Fred n Wilma
2017 Ford F-150 EcoBoost
2015 Crusader 295RST
Fred H. is offline   Reply With Quote
Old 02-08-2016, 06:33 AM   #8
Crusader 816's Avatar
Make sure you have OD off too that way your trans isn't searching for gears all the time.
Crusader 816 is offline   Reply With Quote
Old 02-08-2016, 06:56 AM   #9
Usually Confused Member
emm-dee's Avatar
If one always tows with a WD hitch why is weighing the TV without it relevant?
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
Vengeance 25V (the Harley needed a home)
emm-dee is online now   Reply With Quote
Old 02-08-2016, 07:05 AM   #10
I don't have a TT but I would think you need this weight so you know how much weight you have transferred to the front axles on the truck.
OP, if the numbers you are using are from the brochure those are somewhat fictitious.
Filthy Beast is offline   Reply With Quote
2013, f150
