Old 06-14-2015, 09:19 PM   #1
Can my truck handle this ?
Planning a trip from Ga to Maine this summer pulling my new Surveyer 294 QBLE. Tow vehicle is a 2004 F150,short bed, 5.4, 3.73 rear, 4x4. Am I asking too much from my old warhorse ?
Squid701 is offline   Reply With Quote
Old 06-14-2015, 09:27 PM   #2
Done with this
Dry Hitch Weight 625 lbs.
Unloaded Vehicle Weight 5,793 lbs.
GVWR 7,625 lbs.
I'd say you're pushing it...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 06-15-2015, 05:23 AM   #3
fonzie's Avatar
Read the Ford 2004 towing guide, it will give you info you are looking for....
https://www.fleet.ford.ca/resources/...s/2004_All.pdf
Fonzie
Old 06-15-2015, 09:28 AM   #4
You're right at the top end of that TV's capabilities but you should be ok with a good WDH and some patience.
2011 F150 SuperCrew 5.0 4x4
2012 Flagstaff 27BESS
pappcam is offline   Reply With Quote
Old 06-15-2015, 09:39 AM   #5
wyo700's Avatar
Hook up take your time and enjoy the ride and you and your truck will be fine. You aren't gonna win any races but your towing so who cares.
2012 Sandstorm 203SLC
2013 Toyota Tundra Crewmax 5.7
2014 Honda Pioneer 700-4
2012 Sandstorm 203slc
2013 Toyota Tundra
Eqil-l-izer hitch,Prodigy P3
2004 Yamaha Grizzly 660
wyo700 is offline   Reply With Quote
Old 06-15-2015, 09:55 AM   #6
Pauls Toy Hauler's Avatar
I wouldn't be concerned with being able to pull it. Concentrate more on how it can handle it (swaying & etc.) and most importantly 'Stopping' it.
You will be pushing the boundaries of it's stopping capability. While any tow truck can lock up on less than ideal road conditions you could experience it a lot faster.
Like others have said get a WD hitch. If your trucks squats any amount in the rear when hooking up then you just lost some front wheel manuveribility (front is lighter) and braking power (again front is lighter). bring that truck back to level or even give it a little nose dive. To fix that get you some helper rear springs or better yet adjustable rear air ride.
2015 Palomino Puma Unleashed 351-THSS 37' Toyhauler
2016 F-350 Platinum DRW 4x4 w/ Curt Q24 hitch and Air Lift rear air ride
"Just put that hammer down and give it hell" -Jerry Reed
Pauls Toy Hauler is offline   Reply With Quote
Old 06-15-2015, 10:16 AM   #7
jeff64's Avatar
Last season, I was pulling a JayFlight 24RKS which grossed about 7100 with a '07 F15o SC, 4x4, 5.7, 3:55 LS with a Leer cap. By the time, I loaded all the "other stuff", fuel equalizer WDH and us, I figured we could easily be doing 8,000. Towing capacity of the F150 was 8300. Doable, but, you can't have too much TV.
2014 GMC 2500HD,CC, 4x4,6.0,4.10 w/ cap
2016 Flagstaff 27VRL
Equalizer 14K
Old 06-15-2015, 10:16 AM   #8
[QUOTE=Pauls Toy Hauler;893925]I wouldn't be concerned with being able to pull it. Concentrate more on how it can handle it (swaying & etc.) and most importantly 'Stopping' it.
Towed trailers are equipped with their own braking system, correct? Just asking
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 06-15-2015, 11:04 AM   #9
B and B's Avatar
I would invest in LT tires if not equipped presently. That is the single biggest stability upgrade you can make. Make sure you have proper tranny cooler. I towed a 32 ft Rockwood with a similarly equipped truck (2009 5.4l Triton) at Max capacity and no trailer tow package. It worked.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 06-15-2015, 01:49 PM   #10
[QUOTE=wana65stang;893942]
They assist...not replace.
truck
