05-11-2017, 01:12 PM
Can (should) I tow this (specs in post)
I ran the math and on paper it looks like I should be fine, but I’m looking for the opinions of the gurus on this forum.
My truck is a 2017 Ram 1500, 5.7L Hemi, and towing package with 3.92 gears. Truck weight is 5400 dry, GVWR is 6900, payload is 1510, tow rating is 10160, and GCWR is 15950.
The toy hauler I am looking at is the XLR Hyperlite 29HFS. Dry weight is 7,282 and tongue weight dry is 1,124.
I will be using an equalizer WD hitch rated at 1,400 / 14,000.
In the back of the toy hauler will be a RZR 900 UTV that weighs 1,300.
Two questions, can I safely tow this combination?
And if so, what will the weight of the RZR do to the tongue weight?
Any input help would be greatly appreciated!!
05-11-2017, 01:23 PM
is the 1510 number from specs or from the sticker on the door.
completely empty and assuming that is your actual payload sticker, you have less than 300 lbs to spare. Thats assuming the trailer weighs in correctly as well.
My gut feeling is you are going to be over when real world weights are totaled. ie what payload you actually have from the sticker and what your tongue weight actually weighs. Also, you have no Cargo in the trailer or truck at this point
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
05-11-2017, 01:27 PM
This is the sticker on my truck, so I take it that my payload is actually 1242?
Looks like you'll have less than 400 lbs left of your CCC left with these numbers and that's dry weight tongue weight (which is not reality). Now add you, wife, dog, kids, camping crap in truck and in trailer plus wdh plus full propane tanks. Looking like you're gonna be way over limits.
05-11-2017, 01:35 PM
wow
1,200 lbs of payload available that's pretty dismal. I wonder how in the heck they say you can tow 10K pounds with only 1,200 lbs of payload.. the tongue weight alone on a 10K trailer would have you over your payload..
05-11-2017, 01:46 PM
05-11-2017, 02:06 PM
Toy-haulers are design tongue-heavy unloaded, under the assumption that you will actually be hauling a toy in the back. So, I would assume that factory and dealer options, LP, batteries, etc, plus typical camping gear will add the usual 1000 lbs, plus the 1300 lb vehicle in the back. That total weight (9582) would be distributed to have the 10-15% on the ball. 12.5% = 1198 lbs, which makes your 1400 lbs WDH kit the right choice.
But as has been noted, by the time you consider the weight of the WDH, and whatever you put in the truck, you will be well over your payload capacity.
That looks like the sticker on the TT. Yes? Payload of TT was 1510 I thought
05-11-2017, 02:14 PM
That sticker is from the truck.
05-11-2017, 02:16 PM
Wow. Very low payload number. Will limit what you can have in TT
05-11-2017, 02:18 PM
The cargo carrying capacity of the trailer is 2,642 lbs.
05-11-2017, 02:20 PM
Way too much trailer for your truck in my opinion.
05-11-2017, 02:21 PM
Thank you all for your input!
05-11-2017, 03:35 PM
Scoundrel
I normally think of a Ram 1500 with a 5.7L as having a higher payload capacity than that (my Nissan Frontier pickup has a higher payload than that) and it wouldn't surpise me if you're placard payload number is limited by load range "C" OEM tires.
You might check the Gross Axle Weight Rating (GAWR) front & rear incase a higher load rated tire might help you get more out of your truck.
05-11-2017, 03:37 PM
I was surprised it was so low as well. My tires say don't exceed 2900 lbs. Not sure what range that is.
05-11-2017, 03:42 PM
With a dismal truck payload capacity of only 1242lbs, forget any toyhauler except for absolute smallest ones.
Ram 1500 trucks are infamous for their low payload capacities. The Ecodiesel is even worse.
05-11-2017, 04:28 PM
Even the smaller grey wolf toy haulers would have you over payload.
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
05-11-2017, 05:10 PM
That's crap that the manufacturer give you tons of "pulling " power but nothing to work with for payload
05-11-2017, 05:14 PM
Yeah... Not too happy about that.
05-11-2017, 11:53 PM
Remember, your "payload" has to include occupants. That makes it not so doable. Although I am certainly no expert, I would make sure that my payload exceeded my needs by at least 40%. However, I'm very conservative.
2001 Ford F-350 7.3 dually
2000 Salem T23 (sold)
2015 Vengeance Touring 39R12 (We love it!)
