Old 08-01-2013, 04:11 PM   #1
Carrying a Honda Reflex around on my Georgetown 370XL
I bought this Honda Reflex to avoid towing our car. For some reason I'm deathly afraid of this process, particularly the avoidance of backing up. At any rate, I'm having a devil of a time finding a carrier that will carry this fat little beast (30" width). I bought a cheap ramped hitch mount that didn't work at all. Wouldn't go up ther ramp (no way), too close to the vehicle. A mess. Other motorcycle lift carriers seem too heavy to work with my gas vehicle that has a 141" distance from rear axle to existing receiver. Any suggestion from anyone who has some familiarity with this issue will be greatly appreciated.
jimsaxman is offline   Reply With Quote
Old 08-01-2013, 06:51 PM   #2
lindy's Avatar
What cheap ramp hitch did you buy? I have a ramp type hitch that goes into the receiver on the back of my MH. It can be found at "billybob1.com" The only time I had an issue loading my bike was when the grass was wet.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 08-01-2013, 07:03 PM   #3
Thanks for the reply. The ramp I bought was on Amazon. Chinese make. The ramp had no attachment to the main frame so when we tried to wheel it up, it fell off. Every time. Also the height of the hitch was too high for this carrier. It made the ramp about a 45 degree angle. Not even close to doable for me. Now my wife has me looking at hydralic lifts: Sportlift, Blue Ox, Cruiserlift. But even these talk about diesels rather than gas class A's. It appears the lift is going to cost more than the scooter. Thanks for your input.
Old 08-01-2013, 08:28 PM   #4
VinceU's Avatar
Suggest you look at the weld to frame style. Seems most Georgetowns with Ford chassis only have 4K tow allowance. Your bike plus carrier are over the tonque weight. With the frame style you can pick your height and style.
Old 08-02-2013, 01:56 AM   #5
Absolutely, unfortunately I'm learning as I go. What I'm learning is that welding to the frame (as is the case with Georgetown 370XL) makes a difference. The last 3 ft. of the chassis are an add on extension. So I presume even a 3-receiver weld will be problematic. I was looking as the Blue Ox Sportlift III hydralic lift, but I suspect that may be too much. I sure want to avoid towing something behind me.
Old 08-02-2013, 06:41 AM   #6
lindy's Avatar
Before considering ANY type of hyd lift system go to the Blue Ox site and use the formula they have there to compute the total weight that will be added to the rear axle of your unit once the lift and bike are in place. You'll be surprised at how much weight is put on the rear axle by these hyd lift units due to the distance from the rear axle to the lift.
F.R.O.G. member
Old 08-02-2013, 01:01 PM   #7
Thank you, Lindy, for that. I have done the calculation and its none too good. The welded last 3-4 ft. of our chassis has really reeked havoc with our towing capacity. It seems that any lift won't work with my 350 lb tongue wt. capacity. Towing is the only option. Now the question is car or scooter? Being able to backup is my concern at this point. There is a small travel trailer (6' x 4') that hitch mounts with a single wheel in the back. Does anyone think I can backup with that?
Old 08-02-2013, 07:34 PM   #8
VinceU's Avatar
Frame mounted tow brackets are independent of the tow bracket fitted now. You should talk to a tow shop. Backing 37-38 ft MH to a 6' toad can get ugly. There's a coach next to me with a ramp fitted that is huge, easily can haul a large M/C, no hydraulics though.
Old 08-02-2013, 07:40 PM   #9
VinceU's Avatar
A bracket can reach past the 3 ft frame mod, your problem will be limited by the GVWR, esp. the rear axle rating, not the hitch nos.
Old 08-02-2013, 09:01 PM   #10
Okay. Now I am confused. What you say makes sense, but the companies that sell these lifts say no to the hydralic lift for my kind of rig. Both Blue Ox and Faster Motion. They want to sell me a cheaper product so I have to believe they take this extension business seriously. What I'm looking at is a Swivel Wheel 46 Transport System. They show a video of this thing backing up, making turns, no problem. Anybody have experience with this.
georgetown
