Old 04-14-2019, 11:06 AM   #1
CAT Scale Results
Finally got our fully loaded GeoPro to the CAT scales and have the results. Not how to interpret the results since what I have was not expected. The tow vehicle and trailer were weighed with the EZ lift WDH.
Scale:
Front Axel - 2180 Lbs
Rear Axel - 2780
Trailer Axel - 3120
GAWR:
Front - 2500
Rear - 2352
Occupants + Cargo - 827
GVWR - 4840
Tow Capacity of Car - 3500
Tongue Weight - 312 to 468
Trailer GAWR/PNBE - 1588, 3500
Trailer GVWR/PNBE - 1775
ID:	201683   Click image for larger version
ID:	201684   Click image for larger version
ID:	201685   Click image for larger version
mdulle is offline   Reply With Quote
Old 04-14-2019, 11:27 AM   #2
At first glance it appears you need to unload some weight from your TV rear and/or move that weight into the trailer. The TT has the weight capacity to absorb the weight removed from the TV rear axle but it is also a balancing act to maintain a proper tongue weight ratio.
I ran into similar at the CAT Scales. I removed a lot of stuff from both my TV & TT. And I stopped hauling firewood in the TV
2019 Cherokee Wolf Pup 16BHS
Was 2008 Ford Explorer V6 w/tow package
Now 2019 Ford F-150 S-Crew 5.5 bed V8 w/tow package
Husky Centerline TS WDH 400-600# rated bars
2018 camped 16 nights at 4 GGs.
Boomerweps is offline   Reply With Quote
Old 04-14-2019, 11:35 AM   #3
fonzie's Avatar
At the moment you are over capacity on your Ford Escape Titanium. What model is your GeoPro trailer?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-14-2019, 11:39 AM   #4
19QFB
Old 04-14-2019, 12:00 PM   #5
fonzie's Avatar
Originally Posted by mdulle View Post
19QFB
I don't see that model in Forest River website.
Fonzie
Old 04-14-2019, 12:12 PM   #6
bikendan's Avatar
The OP must mean 19QB.
OP, as I have said, in numerous Geo/E-pro threads, many have no clue how much tongue weight a single axle trailer will put on the tow vehicle.
Having a payload of only 827lbs, makes the heavier tongue weights of a single axle m7ch worse.
You're overloading the Escape by a LOT! The fantasy "dry" tongue of 413, already exceeds the Escape's max hitch weight of 350lbs, BEFORE you add the weight of the battery, options, water and cargo.
You should have bought a smaller trailer, as it's too much for an Escape. With that kind of tongue weight, an Explorer is the minimum needed.
Equalizer WDH
Old 04-14-2019, 12:33 PM   #7
Rockwood GeoPro 19QB
Old 04-14-2019, 07:03 PM   #8
larry2c's Avatar
Looking at your yellow sticker from the Escape you have 827# for TV cargo. If you travel like we do (DW, two fur balls and some "necessities") that could easily add up to 500# which leaves you with only 327# for the hitch. As others mentioned, once the TT has the batterie(s), propane and living essentials it's easy to imagine your TT tongue weight being over that amount.
Another thing to look at is the frontal area of the trailer. Our old ('01) explorer said max frontal area of 50 sqr ft. What is the frontal area of your trailer? For us, the resistance at highway speed caused by the frontal area was the biggest impact when towing with that combo.
I just want to be outside!!!
'17 Salem Cruise Lite 210RBXL
'11 F150 5.0
Two shedding mutts
larry2c is offline   Reply With Quote
cat
