Originally Posted by Boomerweps
Concur. It seems you're pretty close. Measure your front & rear wheel well top with the TT connected on the ball WITHOUT the WDH spring bars attached. Wouldn't hurt to measure the front & rear of the TT, too. Then install the WDH spring bars and measure again. Then you can tell how effective your WDH settings are. Current Ford guidance is to return the front height HALFWAY between unloaded disconnected and loaded connected with spring bars. IMHO, the closer you return the tow vehicle to level, the better. 1/2 ton trucks are designed to be tail high when unloaded. Unless radically angled front high from the load, I'm not sweating the headlight concern. Otherwise, truck makers would have headlight auto level systems installed for differences between unloaded and fully loaded states.
Wheel well measurements are not needed, the OP already has actual cat scale numbers. An adjustment to his hitch, as others have mentioned, is all that is needed to move some weight off the rear axle and distribute it to the front of the truck and back to the trailer axles.
Steve, Barb, and 5 daughters who love to camp
2017 Shamrock 23IKSS, Weight sticker: 5314 lbs, Equil-i-zer 4pt. 1,000/10,000
2006 Fleetwood (Coleman) Niagara: Sold
2004 Suburban 2500 8.1 liter, 4.10, tow rating 12,000, GCWR 19,000, Doorjamb payload: 2108
2003 Suburban 1500 Z71, 5.3/3.73, airbags, LT tires, Big Brake Upgrade, Prodigy P2
