Old 07-30-2019, 12:01 PM   #1
CAT Scale Weights
...Okay, finally got to the CAT Scales. I ran the numbers through a "Actual Weights" site and was a little confused. From what I can tell/understand the rear axle is over weight by 120 lb and tongue weight is 14.4%. Correct?
BTW... Thanks for all the help in getting me this far.
We are loaded up far more than we normally would be as we moving a lot of stuff that normally wouldn't be in the bed of truck.
So it looks like I need to move a 150 lbs or so into the trailer. Am I correct in assuming this? Am I ready to go?
Here is the data:
Truck and TT with WDH engaged:
Steer Axle - 3100
Drive Axle - 3920
Trailer Axles - 5560
GCVWR - 12580
Truck and TT with WDH not engaged:
Steer Axle - 2880
Drive Axle - 4240
Trailer Axles - 5460
GCVWR - 12580
Truck Only:
Steer Axle - 3260
Drive Axle - 2940
The truck is rated:
GAWR Front - 3525
GAWR Rear - 3800
GVWR - 7050
GCWR - 17100
Payload - 1837
Towing Cap. - 11800
Trailer
GVWR - 6499
Mike & Janine
2020 Roo 21SS
2018 Ford F150 XLT... Supercab... 3.5 Eco... 4x4... MAX Tow.. 3.55
MikeT5200 is offline   Reply With Quote
Old 07-30-2019, 12:13 PM   #2
That's a heavy little camper, wow! Yes if you could shed some of your payload you should be golden.
SquiggyFreud is offline   Reply With Quote
Old 07-30-2019, 12:14 PM   #3
Fulltime family RVer
I assume this was the site that you ran the numbers through:
Actual Weights - Travel Trailer/Bumper Pull Weights from CAT Scales - Towing Planner
I made that.
So, yes:
The truck is rated:
GAWR Front - 3525 vs. 3100 actual
GAWR Rear - 3800 vs. 3920 actual
GVWR - 7050 vs. 7,020 actual
GCWR - 17100 vs. 12,580 actual
Payload - 1837
Towing Cap. - 11800 vs. 6,380 actual
Trailer
GVWR - 6499 vs. 6,380 actual
So, as you said - you're 120 lbs. over on the RAWR of the truck but under on all of the other ratings.
The only thing that I don't see you list is what are your tires rated at?
Old 07-30-2019, 12:15 PM   #4
You'll then be close/over on the trailer's GVWR:
  • Trailer GVWR: 6499 vs. 6,380 actual
Old 07-30-2019, 01:07 PM   #5
We're jockeying things around for 150#?
aeblank is offline   Reply With Quote
Old 07-30-2019, 09:52 PM   #6
Go enjoy your trip
moose074 is offline   Reply With Quote
Old 07-30-2019, 10:37 PM   #7
I look at your pic and it looks like your rear is squatting a little to much. It seems to me you could adjust for the 150 lbs to the front axle.
Your front axle is 160 lbs less with the trailer attached than the truck alone.
2016 Siverback 33IK
Old 07-31-2019, 07:44 AM   #8
I made that.
So, yes:
The truck is rated:
Payload - 1837
Trailer
Yes I did...Nice Program BTW.
I swapped the Castle Rocks (which were LRD's) for Goodyear Endurance (also LRD's). They are 2040 lbs at 65 psi. There's not a big choice in 14"
The truck has the stock Goodyear Wrangler - 275/6518R with 116T rating (2756 lbs at 51 psi).
Mike & Janine
2020 Roo 21SS
Old 07-31-2019, 08:55 AM   #9
Jim34RL's Avatar
You could change out the Goodyear tires for a set of Michelins tires. The Michelins tires are LT275/65R18/E 123/120R rated tires. The load index for this tire would be 3417LBS each which will provide an improvement over the stock tires that you have on the truck now.
With the Michelin tires on the truck, I would not worry at all about being 120LBS over your rear axle weight. As the tires are the driving force when computing axle load ratings for the manufacture.
The manufacture really does not look at load carrying ability as much as giving the 1/2 ton model trucks a similar ride like a car has.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 07-31-2019, 08:23 PM   #10
Cat Scale Tickets
I agree.... I was looking at the exact same tire for the truck. I just wish that it was in the budget right now. The stock tires are rated for 2715 lbs each so 5512 lbs far exceeds the 3800 GAWR.
Plus having the truck and trailer loaded this much is really only a 1 time trip (2600 miles).
Mike & Janine
2020 Roo 21SS
Old 07-31-2019, 09:01 PM   #11
...I was think the same thing. However, I would like to stay under all the max weight ratings.
This is a 1 time trip (2600 miles) to be this heavy. I think I'll drain a little more fresh water out and move some weight back to the trailer.
Of course, once I use about 20 gallons of gas I'll be under the GAWR.
Mike & Janine
2020 Roo 21SS
Old 07-31-2019, 10:31 PM   #12
I still think your rear end is sagging. It seems you could adjust the WDH to move that 150 lbs to the front axle. Your front axle weight is 160 lbs less with the trailer connected than truck alone. Just a suggestion...
2016 Siverback 33IK
Old 07-31-2019, 10:35 PM   #13
I wouldn't sweat 150#.
I would agree to bump the WDH one more link though.
Old 08-01-2019, 09:01 AM   #14
Scale Weights
..."One more link"..... Would that be like adding another washer? Won't that also lift the nose of the trailer up?
I have an Equalizer 4Pt.
Mike & Janine
2020 Roo 21SS
Old 08-01-2019, 09:13 AM   #15
Yes, you need to add a washer or 2.
https://www.equalizerhitch.com/manua...on-adjustments
2019 Forester 3011 DS
2015 Jayflight 28BHBE (sold)
2015 Ram 2500 Megacab 4x4 6.4 L Hemi 4.10 gearing
"Is this a game show?"
sugarray40 is offline   Reply With Quote
Old 08-01-2019, 09:13 AM   #16
Mine are chains....
Yes, it would lift the nose of the trailer, too. Looked like it could use it, but a tape measure would confirm it.
Old 08-01-2019, 09:20 AM   #17
Hasn't been said yet, I don't think, but you could just loose the camper shell. That has to weigh at least 120 lbs.
Other wise, it looks like you're setup pretty good. My truck / setup looks very similar, just a longer rig.
Me, the wife, & 2 daughters (9 & 4yrs old)
2019 Palomino Puma QBSS
2015 Silverado LTZ / Z71 w/ many upgrades
GXPWeasel1 is offline   Reply With Quote
Old 08-01-2019, 09:51 AM   #18
Truck should be higher in the back than the front . Yours is not. Springs appear overloaded. Numbers indicate that.
The tongue of the trailer is low.
Need spring help in the back. Sumitro or air bags. I have Timberins. SP
Then you have to adjust hitch heigh. Then adjust bars. Seem good now.
Or do nothing and be happy. If you do not tow much likely you will be ok.
The rear sag damages the drive in 20,000 miles. Causes goofy handling. Poor braking. Blinding other drivers at night is easy to avoid. Do not drive at night.
Half ton trucks do not tow so well when payload is exceeded. I suspect fixing the sag will fix you.
Check the truck tires out. Likely the truck has passenger not lt tires. Not a good thing.
tomkatb is offline   Reply With Quote
Old 08-01-2019, 10:04 AM   #19
Mine are chains....
I did that. The nose of the trailer is 1/8" lower than the back. Perfect.... I thought.
The topper is actually 205 lbs (I believe). We carry some expensive bikes in there (2 mountain and 2 road bikes) plus some cycling gear. It keeps them out of the weather and "some what" safe.
Mike & Janine
2020 Roo 21SS
Old 08-01-2019, 10:11 AM   #20
Needs based on beginning measurements, not compared. Use the hitch manual, took me a couple tries to get mine right when I had a 2011 F150 CC with ecoboost.
cat, weight
