Old 05-15-2013, 05:54 PM   #1
Capsfloyd's Avatar
Cat scales
Took. TT over to get new tires installed
Went to Cat Scales ( 1st time), don't know of done it right but this is what I did
Left the 4 way equalizer hitch on truck and trailer just like going down the road
Pulled on scales up to front to where the intercom was , gave information to him
Me and the wife in truck
Should I've taken off equalizer bars ? And just had the TT setting on the ball ?
The slip of paper showed 4 items >>
Steer axle. 3,000
Drive axle 3,740
TT axle 6,580
* Gross weight. 13,320
How do i I compare the numbers that are on the truck and TT to the scale sheet ?
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 05-15-2013, 06:07 PM   #2
TURBS's Avatar
whats your truck numbers listed on door and door jamb.
gvwr
fawr
rawr
payload capacity .
Old 05-15-2013, 11:36 PM   #3
Capsfloyd's Avatar
gvwr
fawr
rawr
payload capacity .
This was on the door
Trucks
Trucks
Front. 3700
Rear 3900
GVR. 7800
2010 jeep Liberty
Old 05-16-2013, 07:30 AM   #4
MtnGuy's Avatar
Ideally, you should go across the scales 3 times with the passengers and cargo in the same position each time
1. Truck and trailer with spring bars.
2. Truck and trailer without spring bars.
3. Truck alone. I just drop my trailer in the back lot while doing that.....nobody has even complained.
Not knowing what your truck alone front axle weight is, it is a little hard to determine how the WDH should be setup. My initial thought is that you probably need some more wight distributed to the front axle.
Old 05-16-2013, 08:55 AM   #5
Herk7769's Avatar
I started working on a post, but since it was getting REALLY long, and I needed to take the DW's car in for inspection, I finished it as a PDF while I waited for the car.
This way I can just upload the procedure I use (one for Travel Trailers and a different one for 5th wheels) to the library.
Herk
http://www.forestriverforums.com/for...do=file&id=128
There are 2 OTHER files on how to weigh your travel trailer there as well.
Here is the one for the 5th wheel
http://www.forestriverforums.com/for...do=file&id=129
HAM CALLSIGN - KC3FFW
