Old 05-03-2013, 10:08 AM   #1
CAT scales and WDH question
Pardon my thickness, but I thought I had the procedure for weighing our TT figured out then I started thinking about the WDH. Does the WDH affect the math figuring afterwards?
I believe you should put the spring bars in the truck for the truck only pass?
Also, a month or so ago, someone posted a nice summation of the procedure on a spreadsheet but I can't find it. Anyone know the thread? I think it might have been a "Fred" something in the username?? I printed it but can't find it now.
Off to the scales this weekend.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 05-03-2013, 10:38 AM   #2
Roll's Avatar
This is a subject near and dear to my heart. I have tried in vain to get a weight for each wheel for our coach.
Getting an axle weight is not too difficult and I have that.
I've been using a new set of CAT scales at a local truck stop. These are the scales that are self serve type where you push a button to talk to a cashier inside then park and go in to get your weight.
They have a 3 foot pad at scale level on either side of the scale and the scale is set up in 4 sections. I tried pulling on with my left side wheels off the scale, riding on the concrete pad. I had the right side wheels on two separate scale sections and the left side wheels completely off the scale. The idea was to get a front wheel and rear wheel weight. Then I did the other side pulling the right side tires onto the concrete leaving the left side on the scale. Thought I had this licked.
But no, instead of getting two weights, front and rear for each ticket it gave me the total "side" weight. That was a dissappointment. (I was clearly on two separate scale sections.)
I know that I am under capactity on the front axle by 1200 lbs (6800/8000) and under weight on the rear axle by 1800 lbs (13200/15000), but I didn't know what the weight is side to side.
I discovered in the failed attempt to get individual wheel weight that I was loaded 550 lbs heavier on the right side than the left side, I just don't know where that weight is, front or rear, or a combination.
Frustrating....
Gary, Cindy, Reacher (Maine Coon), and Vivian (in spirit only now).
Retired: July 31st, 2013 and loving it.
__________________________________________
2011 Coachmen Encounter 37 TZ pulling a 2012 Wrangler Unlimited Sahara. Many upgrades, additions, mods, and changes.
Roll is offline   Reply With Quote
Old 05-03-2013, 10:48 AM   #3
Engineer of Crazy Train
ChooChooMan74's Avatar
I bet you Doug should be here shortly. He has been a weight fanatic lately :-P
Putting the bars in the truck would make sense, since they are more attached to the truck.
TV - 2015 Ram Truck EcoDiesel
TT - 2015 Rockwood Roo 183
Locomotive Engineer
Nights Camping --- 2015 - 19 Camped | Winterized -- 2014 -18
Come read my Camping Blogs
ChooChooMan74 is offline   Reply With Quote
Old 05-03-2013, 10:49 AM   #4
Indymule's Avatar
OK so what is the reason for needing each wheel weight?
Is the vehicle handling poorly or some unusual wear one side?
Jay & Maria - Camp Dog Joplin
2018 Cedar Creek Champagne 38EL
2017 Ford F350 Crewcab Dually Diesel
Ham Callsign K9NDY
Indymule is offline   Reply With Quote
Old 05-03-2013, 10:58 AM   #5
Fulltime family RVer
Since I've been summoned ... no clue. Never used WDH- but if it were me, I'd throw them into the back of the truck since that's where their weight normally sits.
Old 05-03-2013, 11:18 AM   #6
This will be my first experience at a CAT scale. Not sure what it will be like if teeming with semis and rough looking drivers.... Am planning to wear my best wife-beater T-shirt and telling them to go sit in line. No fear here!
If you can fit it in, I think it would be nice to know your left and right side weights so you can try and balance your payload if possible. Should make for a little better handling and less tire wear - theoretically speaking. If you have a long slide on one side, not sure how you could balance it out other than adding some big rocks on the other side.
If I find out I do not have our Reese dual cam hitch dialed in close enough, I am not looking forward to unhooking, adjusting things and taking another pass. Am looking for 25% weight transfer to the front, 50% to the rear and 25% to the trailer. Measuring the drop of the front and rear of our truck says I should be close but who knows.
Langley, BC
Old 05-03-2013, 11:26 AM   #7
It's intimidating, that's for sure. But- I've never bad any bad experiences. In fact, as I was backing into my spot to drop the camper, a truck driver saw me stretching to see my corner in my mirrors. As I was about to jump out to look, he smiled and waved me to keep going (showing me that I had room). I was able to ease on back into the spot from there.
Once parked, unhitching and re-hitching wasn't bad.
I've not seen CAT scales that you could get side-to-side measurements.
Old 05-03-2013, 11:40 AM   #8
Canadian Member
itat's Avatar
Go to this thread. It should have all the info you'll need.
Weight Issue
Here is the URL for the CAT Scales website:
CAT Scale
You'll find lots of great info on their scales, how to use them and where they're located.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer WDH
2009 Ford F-150 XLT SuperCrew, 5.4L, 5'6" bed (2012 - 2016)
Old 05-03-2013, 11:55 AM   #9
I ran into one Butt of a truck driver when I tried to drop my trailer in the back of the lot. He was bullshit because it says no parking, yet other trucks parked there. He didn't swear in front of the family...that would have gotten ugly.
Locomotive Engineer
Old 05-03-2013, 12:18 PM   #10
Was it this thread? Document for calculating your weight capacity
Force did a nice job, but I'm not sure it was ever posted anywhere for download.
Len & Cheri is offline   Reply With Quote
cat, scales, scaling
