Old 08-26-2014, 08:36 AM   #1
Cedar Creek 36 CKTS tow vehicle
After the FROG Rally this year we've decided to upgrade to a Cedar Creek 36 CKTS. We are searching for a vehicle to tow it and have found a 2012 Ford F250 King Ranch, single axle, Power Stroke Turbo Diesel. Will this pull the Cedar Creek? The CC shows a pin weight of 2500# and a loaded weight of about 16,000 pounds.
Any advice helpful!
snormaniii
snormaniii is offline   Reply With Quote
Old 08-26-2014, 10:55 AM   #2
jtstromsburg's Avatar
I think it would pull it, but most likely going to be well over the trucks allowable pin weight. I think your in 1T range with that camper. Pin weight will most likely be in excess of 3000lbs once loaded. If you had the truck already, I'd say go for it. But since your in the market for a new truck, I'd look for a 1T.
Joel and Teresa
2016 Sabre 34TBOK
2006 GMC 3500 CC LB DRW 4X4
jtstromsburg is online now   Reply With Quote
Old 08-26-2014, 11:39 AM   #3
My choice would be at least a 1 ton dually,
dblr is offline   Reply With Quote
Old 08-26-2014, 05:45 PM   #4
I have a 2011 F250 CC diesel longbed RWD and I would not tow a fiver of that size. Your pin weigh, RAW and combined weight will be over the limits. I would have a dually one ton and up for a 16,000 lb fiver. Good Luck
whj77372 is offline   Reply With Quote
Old 08-26-2014, 05:59 PM   #5
mcnabbwr's Avatar
A one ton truck would be the best solution however a dually is not needed. If 16000 is your loaded weight the single rear wheels are rated for around 17000 and more. Decide which vehicle you may want and check its maximum tow capacity.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 08-26-2014, 07:53 PM   #6
GreenImp's Avatar
Send a message via MSN to GreenImp
Here are the towing capacities for the 2012 model year F-250's (from fleet.ford.com). Your payload capacity will almost certainly be your limiting factor though. You will need to get that off of your specific trucks "Truck Safety Compliance Certification Label". Whether or not to go over your weight ratings is a personal choice.
When looking at used trucks, make sure you pay attention to what wheels and tires are on it, as they could easily have been changed to something rated for less than the original.
Name:	beach sites.jpg
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 08-26-2014, 08:28 PM   #7
Check this outTow Test Review: 2011 Ford F-250 Super Duty, Part 1 - PickupTrucks.com News
I know it's a 2011 F250 but I doubt much changed.
IMO a 1 ton DRW.
goduc is offline   Reply With Quote
Old 08-27-2014, 09:15 AM   #8
Tow Vehicle 36 CKTS
Thanks all for your input. Looks like an F350! Looking forward to joining the Cedar Creek owners!!
Scott
cedar creek, tow vehicle
