Closed Thread
Old 12-19-2014, 10:46 AM   #1
Cedar Creek Tow Vehicle
We are going to go to a Cedar Creek 5th wheel - 36ckts and need some advice on truck purchase. Have been told that a 3/4 ton diesel will work and are undecided on Ford or Ram. Any advice? Will be our 1st 5th wheel - currently have a class C.
justbob is offline
Old 12-19-2014, 10:48 AM   #2
Can't go wrong with either. Pick you color, which one looks better to you, find your best deal, and They are all so good now, you just can't miss...
taken is offline
Old 12-19-2014, 11:33 AM   #3
Fulltime family RVer
Ford vs. Ram vs. Chevy - all 3 make great trucks. As said, pick your color and options and roll!
As for 3/4-ton vs. 1-ton- I'm of the opinion that people should be educated on this and not just have some anonymous person on the Internet tell them what to do. Your experience/driving abilities/comfort level may be different than mine. For me, I'm still a "by the books" kind of guy- that means, you need to have a truck with enough payload to be able to carry the weight of the fifth wheel as published on the door jamb.
The 36ckts has a dry pin weight of 2,500 lbs. (per the specs) which will give you a realistic loaded pin weight of over 3,000 pounds (per my calculator).
Adding in your people weight (driver, passenger(s)), pets, tools, truck add-ons, fifth wheel hitch, ect. -- you could/may be overloading a 3/4-ton truck. The question comes- what is your feeling on this? We can't answer that and IMO, no one should blindly say you need a 1-ton or blindly say that a 3/4-ton truck is fine.
ependydad is offline
Old 12-19-2014, 11:42 AM   #4
I couldn't agree more. Unfortunately being educated takes a bit more than taking a 5 second gander at the sticker on the doorjamb which means precisely nothing... First off, the sticker on the door doesn't take into account the actual weight of the truck when ready to tow. The only real way to get your payload is to get your truck weighed and subtract that number from the trucks GVWR. Then subtract your actual weight from that GVWR and now you have it's actual physical rated payload.
taken is offline
Old 12-19-2014, 12:12 PM   #5
One of the main issues for me if I were in the market for a 250 or 350 is availability. Seems to be 10x as many 250's as 350's, at least in my area. You can order a 350 they way you want, but the factory rebates can change between order time and delivery costing you thousands. But I can likely find a 250 just like I want it nearby.
dustman_stx is offline
Old 12-19-2014, 12:52 PM   #6
I was also thinking that the Cedar Creek may be a little heavy for a 250/2500?
I picked up a booklet at the last RV show in Houston, February 1014, and I remember thinking that they were a little heavy for my 2011 F250. Good Luck
whj77372 is offline
Old 12-19-2014, 02:30 PM   #7
As stated before, I know little to nothing about trucks. As such, I'm not willing to debate if they're identical or different outside of saying that I'm a bit skeptical given that their base prices are different:
Ram:
2015 Ram 2500 Heavy Duty Work-Ready Truck
2015 Ram 3500 - Heavy Duty Pickup Trucks
Ford:
2015 Ford Super Duty | Pricing, Financing, Leasing & Ford Incentive Offers | Ford.com
Chevy:
Build Your Own Truck: 2015 Chevy Silverado 2500HD | Chevrolet
Build Your Own Truck: 2015 Chevy Silverado 3500HD | Chevrolet
It ranges from a couple of hundred dollars to a thousand plus. That's a lot of money for a sticker.
Old 12-20-2014, 03:47 PM   #8
I have a 36CKTS. I traded in a Ram 2500 diesel for a Ram 3500 DRW diesel. The 2500 was over in pin weight but pulled it fine. I wasn't comfortable and it's a gray area with that configuration. The 3500 is not over any weight limits and handles the 36CKTS beautifully. I'm a happy camper.
Bill & Joy
Daisy & Roxie (our Poms)
2015 Cedar Creek 36CKTS
2014 3500 Ram Laramie Mega Cab DRW Cummins 6.7L Diesel
bturner is offline
Old 12-20-2014, 04:50 PM   #9
davel1971's Avatar
check out single rear wheel 1 tons. Way more payload capacity than a 3/4 ton, not quite a dually. A good "in between" option. I love mine
David & Lynn
davel1971 is offline
Old 12-20-2014, 05:40 PM   #10
CCRVOC
Ramblin Recks's Avatar
Can't speak to a 2500 but our 3500 DRW handles our 36CKTS perfectly.
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline
Closed Thread
