Old 12-27-2015, 10:58 PM   #11
trbomax's Avatar
A torque wrench should never be used to break nuts or bolts loose that are already tightened.The shock that is imposed on the mechanism when the bolt.nut is broken loose will degrade its use as a torque measureing device.That info is pretty much auto shop 101.
trbomax is offline   Reply With Quote
Old 12-27-2015, 11:10 PM   #12
2X
Tim
TimVWulp is offline   Reply With Quote
Old 12-27-2015, 11:10 PM   #13
Oklahoma Proud
MillerTime's Avatar
Yep. And always store it a -0-
Also a side note....the new lithium batterys don't loose charge like others. I've had them hold full charge for months.
2nd side note......you can jack on the axle by the u bolts on a leaf spring axle, just try to stay as close to the hub as you can. While its best to use the frame on a torsion axle.
Old 12-28-2015, 08:00 AM   #14
CWSWine's Avatar
Anybody use these?
http://www.amazon.com/dp/B001V8UKBO/...8MDJIE8G&psc=1
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-28-2015, 08:43 AM   #15
steelpony5555's Avatar
Guys this is a cheap HF torque wrench that lives in my toolbox on my truck just for changing flats or if I ever have to remove a tire and retorque the nuts.....it is not something I would ever use to build an engine....but in the world of not a lot of space to carry my entire tool box it will do fine if I change a tire every 2-3 years....
From Central Texas
2014 Cedar Creek Silverback 29IK
2010 Dodge Laramie 3500 Dually
My Steelpony....2007 HD Ultra Classic...done up in a memorial to the 343 firefighters who died 9/11
Never Ever Forget....yes I was a Volunteer FF for 20 years........
steelpony5555 is offline   Reply With Quote
Old 12-28-2015, 08:49 AM   #16
rmac04401's Avatar
Did you mean to upload a pic?
2016 Grey Wolf 26rr
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 12-28-2015, 09:02 AM   #17
Don't need no torque wrench to change a flat...impact it off and on and get moving. Check torque at a later date when it's safe.....
Bartlett is offline   Reply With Quote
Old 12-28-2015, 09:04 AM   #18
Kenny kustom's Avatar
X2.
Also, if you used that tq wrench to remove the lugs, I wouldn't trust the tq anyways..
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
I am nice!
2017 Dynamax Isata 4
Old 12-28-2015, 09:27 AM   #19
You might want one of these too..
Jiffy Jack | Hitches Online
2016 Siverback 33IK
2015 Ford F-250 Lariat 6.7L V8 Diesel 4WD Super Cab
Old 12-28-2015, 10:08 AM   #20
Blackhat6mike's Avatar
Trailer Aid has the same type ramp for under $50 on Amazon. Make sure you get the TALLER one. It's worked for me on 4 occasions. Super simple and much less dangerous than a jack. IMHO...and personal experience.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
