Old 12-28-2015, 10:14 AM   #21
nomad297's Avatar
Yes..and? I always use a breaker bar for the tear down and a torque wrench for the tighten up.
Bruce
nomad297 is online now   Reply With Quote
Old 12-28-2015, 01:18 PM   #22
northstar1960's Avatar
Originally Posted by Bartlett View Post
Don't need no torque wrench to change a flat...impact it off and on and get moving. Check torque at a later date when it's safe.....
well that way might not be best . as the new 20 v impact will bust a lug right off ,350flbs best to snug em up and since you'll be doing it by hand may as well use a torque wrench
northstar1960 is offline   Reply With Quote
Old 12-28-2015, 02:56 PM   #23
Originally Posted by CWSWine View Post
Just be advised that these don't work on units with extended wheel spacing. Don't ask how I know, but I do have an unused Andersen one.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 12-28-2015, 09:03 PM   #24
Thanks everyone for the responses.
I think I'll try my 1/2" or a 3/4" breaker bar & socket with a cheater bar (haven't carried one of those in a while). And make sure the lugs are torqued properly not slammed on by the garage.
I'll let you know after the new year if I break all 56 lugs!
GypsiesAtHeart2016 is offline   Reply With Quote
Old 12-28-2015, 09:51 PM   #25
mud yapster's Avatar
Well I use a 1/2" break over bar then a 1/2" torque wrench to set the lugs myself. I also carry a 12 ton bottle Jack. Hope to never use any of them on the road side to change a flat but you never know with all the China tires now days. I also carry a road side emergency kit with triangles and the likes. Some states also require it for RVs I've read but don't know for sure. It can't hurt to have the road kit.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 12-30-2015, 04:39 PM   #26
CWSWine's Avatar
Looks like there is two models and one labeled the "Plus" is made for RVs with extended space between the wheels. Mine doesn't but I still order the Plus anyway since it was on sale for 35.00 on Amazon and with prime free shipping.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
CWSWine is offline   Reply With Quote
Old 12-30-2015, 05:41 PM   #27
Stupid question: I'm assuming driving one wheel up on a ramp/spacer will work with the Dexter axles? Not sure how high up you'd have to go.
Thx
JeffandLori is online now   Reply With Quote
Old 12-30-2015, 06:01 PM   #28
rsdata's Avatar
Harbor Freight
Breaker bar and lug nut assortment
all you need besides a jack
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 12-30-2015, 06:18 PM   #29
another_newfie's Avatar
Breaker bar and torque wrench. No need for a zebra hunt and good ole hand tools rarely let you down. Keep the lugs tightened to spec to avoid bursting a blood vessel breakin em loose.
2015 F-350 SRW 6.7 PSD
2014 Crusader 295RST
1 Fantastic DW
1 Amazing DD
1 Beagle that will be missed (RIP Zeus)
another_newfie is offline   Reply With Quote
Old 12-30-2015, 06:59 PM   #30
Hello Gypsie,
I know you asked about how to get a wheel off/on, and get back on the road quickly. While some tire failures will require this, in my years towing a trailer, puncture related flats have been the only type of tire problem I have encountered (knock on wood now that I have cursed myself).
A good "string plug" type tire patch kit and 12V air compressor have saved my bacon many times. Even in the worst cases this has allowed me to get to a facility where the proper repairs can be made.
pjnlorrie is offline   Reply With Quote
