02-29-2016, 01:43 PM
#21
I have a small bottle jack and small piece of 4x4 wood. But I was just wondering:
Has anybody tried this with Lynx Levelers?
The standard Trailer Aid gives 4.5" of lift. My 10-pack of Lynx Levelers gives the same 4.5" in a 4-3-2-1 pyramid.
02-29-2016, 02:04 PM
#22
Trailer aid Plus
I got this and it is amazing. Super easy.
http://youtu.be/755hmEWAW_c
02-29-2016, 02:05 PM
#23
Always Learning
I've used a 5-block high ramp with LynxLevelers and my second tire was still firmly on the ground. I think that even with the Trailer Aid, I'd have to do something to raise it. Don't own one, though.
02-29-2016, 02:06 PM
#24
No night traveling for us
Originally Posted by PenJoe
We had just over 300 miles on a new TV and hit road debris in the center lane of an Interstate, ruining a nearly new tire. It was dark, blacktop pavement, and raining- too late to avoid when we saw it.
Exactly what happened with us and now we just don't travel at night. Our accident didn't tear up a tire, but it did tear up a good chuck of lower fascia on the 4 month old trailer.
D_B Travelers - 39 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
02-29-2016, 02:08 PM
#25
I'm blessed I don't have to use a jack anymore, it stays home more room for beer
#26
Ahhh, hydraulic 6 point self level in manual mode.
02-29-2016, 02:13 PM
#27
txkreddog
Originally Posted by Sandy12345
Just so I am clear on this since I'm fairly new to Rving, If i pull my front tire onto the trailer aid it will lift the rear tire enough to change it?
I suggest trying out the trailer aid plus before you actually need it. It definitely sounds like the easiest and safest way to go, if it works. It must do the job on lots of other TTs, but it doesn't lift high enough for mine to get the flat tire off the ground. Ended up giving it to my brother for his TT. Some have told me the distance between the front and rear tire makes the difference.
02-29-2016, 02:18 PM
#28
My hydraulic jacks will pick my trailer up in manual mode.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
USS Pyro AE-24 WestPac MM2 '71-'75
02-29-2016, 02:28 PM
#29
Be advised the Trailer Aid will not work with TTs having the spread axles such as mine. You may be able to stack enough blocks in step fashion to make it work, I haven't tried but I did try the Trailer Aid and it didn't work.
George Scott
2015 Salem Hemisphere Lite 272RLIS
2006 Heartland BH 3400/Summer Home
2021 Sabre 37FBT
02-29-2016, 02:30 PM
#30
Alleged curmudgeon
I use a Trailer Aid with my torsion axles. However, my axles are NOT spread. It works great.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34); 2018 (39); 2019 (30); 2020 (16); 2021 (14); 2022 to date (12)
02-29-2016, 02:38 PM
#31
What are spread axles?
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2002 Goldwing 1800GL CSC Trike
2020 Ram 2500 Crew cab 6.5 bed
Ron & Shirley (Empty Nesters)
02-29-2016, 02:41 PM
#32
I have a Trailer Aid and doesn't work on my 5er. I have the Lippert 4000 suspension which has 4" of travel up and down so just not high enough. I haven't tried stacking wood or level blocks under but it would probably have to go up another 4 inches to work.
2017 Fleetwood Discovery LXE 40D Diesel Pusher 41 foot. CC 5740
2017 Solitude 310GK-R Pick Up Oct 24th.
2016 GMC Denali 1 ton Cargo Capacity 3722 lbs
Sold 2016 Keystone Montana 3711FL
Sold - 2015 Crusader 315RST 5th Wheel -
2015 Ford F350 SRW Cargo Capacity 3744
02-29-2016, 02:42 PM
#33
They are approximately 14" between axles, vice 3 to 5". Some newer units are seeing this type of set up.
George Scott
2021 Sabre 37FBT
02-29-2016, 02:48 PM
#34
I'm not sure of the actual distance in inches. But the two Forest River trailers I had, one had axles that were close together, the other the spread axle design were further apart. I could lift one tire off the ground using my level ramp on the regular axle. On the spread axle the other wheel is still touching the ground.
2012 F150 FX4 Crew 5.0 3.73
2012Coachman Freedom Express 292BHDS (outdoor Kitchen)
02-29-2016, 03:09 PM
#35
I'm going to call Good Sam and make coffee
2022 Montana 3855 BR
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
02-29-2016, 03:26 PM
#36
Changing tire
I have had flats and blowouts, but haven't changed a tire in 25 years, maybe more. I call AAA, they change it. Worth the wait.
Especially when it is the highway side.
02-29-2016, 04:28 PM
#37
I bought GS Roadside Assistance and let them carry the equipment and change my tire.
Marcel & Jenne
Kemptville, ON
2014 Rockwood 8282WS
2015 Ford F150 Eco-Boost
02-29-2016, 05:09 PM
#38
Good side of getting old you can retire and enjoy life - The down side of retiring those heavy truck tires are to heavy for you to change. I also subscribe to roadside service since my back operation last year.
I got from my car insurance agent and when I asked it would cover my 5er while towing.
02-29-2016, 05:13 PM
#39
Left Coast
Thing is, I'd rather be going than sitt'n...
02-29-2016, 05:36 PM
#40
I have a trailer aid and it worked fine for my old fiver with 15" tires, but I'm not sure if it would work with the 29RE with 16" tires. I'll keep it because I have a tandem axle utility trailer for hauling the Kubota.
I just rotated the tires on the camper this morning and used the levelup system in manual mode. What's really neat is that both wheels on one side can be lifted at one time. Worked great, and didn't take but 20 minutes to do both sides and I checked the mail somewhere in there...lol The impact wrench helped too.
One of the things they don't tell you is that a regular socket will not fit around the lug nuts because of the lack of clearance between the lug nut and the recessed opening in the wheel. I found a thinwall deep socket that works okay, but forget using a four way, plus the lug nuts are 19 mm, which, of course is a different size than the truck.
2016 Ford F-350 Lariat CC, 4x4 SRW. B&W turnover with extender. 2015 CC Silverback 29RE, fitted with Reese Goose Box. Amateur Extra Class K5TS, 2016 nights camped 16
